I've never heard of it but saw some encoder talking about it in the comments section today so I got curious. can someone explain what's that please? thank you.
Results 1 to 10 of 10
Thread: what is crf17?
In what comments section ?
It's a quality-based setting in popular open-source video x264 and x265 (possibly others that I'm not aware of). The lower the number, the higher the quality, but also the size of the resulting file ; the higher the number, the lower the file size, but also the quality (more data from the original video is discarded). With x264, a CRF value of 17 usually yields a very high quality, almost indisinguishable from the source ; 20 is usually considered a good compromise ; a CRF set to 0 theoretically produces a lossless compression. At the opposite side of the spectrum, high CRF values above 25 (as used in some popular movie releases from teams with names ending in “...mous” or “...FY” with sizes below 800MB for a full length movie in 1280xXXX resolution or less than 2GB for a 1920xXXX resolution) result in a significant loss of detail, conspicuous banding, and egregious artifacts, especially on dimly lit or fast moving scenes. The advantage over a bitrate-based setting is that the user doesn't have to set a specific bitrate (different sources have different bitrate requirements), the encoder analyses the source based on its own metrics and automatically allocates the bitrate it deems necessary ; the disadvantage is that the final size of the compressed file is not known in advance. -
thank you for teaching me that, as for the comment section it was on a release by a team called "df...". I'm also curious now if the crf0 works as efficiently in practice as in theory
MediaInfo reports the encoding parameters if they are embedded in a video file. For instance this :
Code:Encoding settings : cabac=1 / ref=4 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=3000 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=62500 / vbv_bufsize=78125 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Code:Encoding settings : cabac=1 / ref=8 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
As for crf=0 being lossless, I didn't do tests to ensure that it is indeed the case, but I can quote this from here (from “jagabo”) :
For crf=0 both are lossless so both are the same quality.
x264 CRF=0 is lossless, but most NLE's don't understand it on import (can't decode it) .
H.264 (including x264/ffmpeg version) is not lossless, period.
- Less-lossy, sure.
- Lossless, no.
x264 does support lossless, period. I don't use it for that but it does support it. There's some quibbling over if you need to use CRF=0 or CQ=0 to get lossless, I forget which or maybe both give lossless. But it does support it.
https://forum.videohelp.com/threads/358901-is-x264lossless-really-losslessLast edited by abolibibelot; 5th Oct 2021 at 15:57.
x264 lossless is definitely lossless -- as long as you don't have any color format changes. The people who don't believe this were performing a color format conversion and not realizing it. For example, if you feed the encoder RGB24 it will be converted to YUV 4:2:0 then compressed. On decompression the YUV 4:2:0 video that comes out of the decoder is identical to the YUV 4:2:0 that went in. But if compare to the original RGB24 it will not be identical -- the RGB to YUV and back to RGB conversions are not lossless.
But CRF 0 is much like other lossless video encoders -- it produces very large files. Someone who's used to CRF 17 encodes will find CRF encodes are ~10 times larger. -
CRF is designed to produce a similar visual quality, to encoding with a constant quantiser, but at a lower bitrate.
There's an overview of x264's rate control methods here.
https://forum.videohelp.com/threads/381668-would-it-make-more-sense-to-use-1-pass-enco...65#post2470457Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview) -
that this only means that the quality is similar throughout your one clip with exactly the settings you use, if you change the clip or a setting all bets are off
So encoding source A with settings A and encoding source B with settings A can produce wildly different quality even if they use the same crf.
Also crf does not restict the file size so just because source X came out as 100MB, does not say that source Y (even if it has the same resolution&co) wouldn't come out as 500MB.users currently on my ignore list: deadrats, Stears555, marcorocchini -
note that this only means that the quality is similar throughout your one clip with exactly the settings you use, if you change the clip or a setting all bets are off
So encoding source A with settings A and encoding source B with settings A can produce wildly different quality even if they use the same crf.Last edited by abolibibelot; 31st Oct 2021 at 20:14.
In math, X - 0 = X and Y - 0 = Y. And X - 0.5X = 0.5X and Y - 0.5Y = 0.5Y, but that doesn't mean X = Y.
Scott -
But that part puzzles me — isn't that the whole purpose of target quality settings,
It's the same with 'constant quantizer', it's also not the same as 'constant quality'.
crf is no rate control mode that targets a specific quality, it seems like you assume sonething as basis of your thinking which is wrong.
crf is not something that aims to archive a specific PSRN/SSIM/VMAF/VQA/... value.
May be reading https://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.135.7528&rep=rep1&type=pdf helps a bit or it confuses more.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
