I think I've seen a lot of misinformation. From my understanding the preset setting only affects compression not quality. My questions are, does setting the ffmpeg -preset affect quality? Likewise do different settings on the Encoder Preset in Handbrake ever affect quality?
I've read things like this for handbrake "Behind the scenes, the speed slider tells ffmpeg to either use or ignore certain types of compression opportunities that requires more CPU resources. Losing those opportunities decreases quality while having less of an impact on filesize that you'd think." Again this doesn't add up from other sources where I've read it has nothing to do with quality.
One can only compare the quality on the basis of equal file sizes, not just on the selection of some 'presets' of different tools.
Presets have different meanings, they can be quality based or device based (for playback compatibility), for example.
Bottom line: A preset affects efficiency, means speed, visual quality and compression. So for the 'quality' comparison one should compare the results based on same encoded file size. -
Thanks for the reply. The reasoning for asking the question above is because I'm trying to create lossless QTGMC deinterlaced files for editing. I've included what the ffmpeg manual says below. Is it saying that both are the lossless because the crf value is 0 so the preset speed doesn't matter? If I'm trying to achieve the best quality does using ultrafast as a preset matter?
You can use -crf 0 to create a lossless video. Two useful presets for this are ultrafast or veryslow since either a fast encoding speed or best compression are usually the most important factors.
Fast encoding example:
ffmpeg -i input -c:v libx264 -preset ultrafast -crf 0 output.mkv
Best compression example:
ffmpeg -i input -c:v libx264 -preset veryslow -crf 0 output.mkv -
Both are lossless.
The preset veryslow will require more CPU power and takes more time. The file size will be smaller. Simply speaking it's similar to a .zip which is smaller than the unzipped original, but still lossless. -
Just be prepared that x264 lossless (using any settings) isn't as compatible in most NLE's as some other lossless codecs. You have to try it out what your editor accepts.
Other codecs might be more suitable as lossless intermediates.
From this post by “poisondeathray” :
For crf=0 both are lossless so both are the same quality. Only the file size will differ (how much depends on the particular video). But at any other crf value the slower presets deliver better quality than the faster presets. And with the exception of ultrafast and superfast the sizes usually won't vary by more than about 10 percent (ultrafast and superfast are much larger, especially the former). And the variance isn't linear.
But why take anybody's word for it? Just try a few test encodes see for yourself.
Handbrake converts to 1214x536 instead of 1280x720 using Fast 720p30 preset
By Fozzie_Bear in forum Video ConversionReplies: 4Last Post: 17th Apr 2020, 11:19 -
ffmpeg preset
By vidblue in forum Video ConversionReplies: 1Last Post: 4th Apr 2020, 15:03 -
MAGIX HEVC/AAC MP4 settings, preset quality, what does it affect?
By SF01 in forum EditingReplies: 5Last Post: 14th Mar 2020, 12:07 -
Handbrake Preset For PSVR (version 2) ?
By Startropic1 in forum Video ConversionReplies: 0Last Post: 3rd May 2019, 16:27 -
Recreate Handbrake Preset from MediaInfo?
By mdragoni in forum Video ConversionReplies: 1Last Post: 6th Sep 2016, 10:27
