My dvd's work fine after burning them however, the menu that I create only flashes on the screen for about a half a second, and then the screen goes white and you can kind of tell that the start button is there, after I press play on my remote it plays the dvd fine. It's not like I'm creating some complex menu either, I've just made a screen shot that I like for the background image, then make a "start" button, choose the silent sound for the sound option and add the menu to the job... can anyone tell me what is wrong, or what I'm doing wrong?
well to convert, avi2dvd with HCEnc for the encoding, using nero to burn the vts files...playing it back on my dvd player, which is a JVC proscan, or my magnavox proscan, does the same thing on both and my power dvd program on my computer... flashes the menu screen for a split second..then goes blankOriginally Posted by guns1inger
DVD-Lab pro menu problem
By wackman in forum Authoring (DVD)Replies: 4Last Post: 26th Aug 2008, 05:52 -
TmgEnc DVD Author Menu Problem
By powerkoala in forum Video ConversionReplies: 9Last Post: 25th Sep 2007, 14:19 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 20:43 -
TPMGEnc DVD Author 3 Menu Problem
By ^D3vIL^ in forum Newbie / General discussionsReplies: 4Last Post: 16th Sep 2007, 18:43 -
DVD Menu Flash problem
By jcubz in forum Newbie / General discussionsReplies: 10Last Post: 15th May 2007, 23:26
