Hi
I'm converting avi to dvd with menu but the dvd menu is not showing up on the dvd player
the movie is auto starting and no menu showing up in the beginning
but when i press the menu button on the remote controle the menu shows up when the movie is playing
Software TPMGEnc DVD Author 3
You should be able to change the firstplay action. But I haven't used tda 3 just 2. But I found this from a guide:
Finally, the "DVD playback settings" page (you will see this page as well if you selected to use a template) allows you to choose the actions that the DVD player should take when it first loads the disc and when it finishes playing a particular track. The options you see here depend on your other menu options and on how many tracks you have. If you have multiple tracks and a top menu, you should see a screen similar to the one below. The options are all fairly obvious, but the option that commercial DVDs use for multi track DVDs is "Display the top menu" for both settings. Press "OK" to end the menu creation wizard. -
When you create a menu using TMPGEnc, you have the option to make it autostart the video or display the menu first. This is in the 5th section of the Menu creation procedure, called "DVD playback settings". You'll want to select "Display the top menu" on the top section. Example image upcoming.
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 19:20 -
TPMGEnc DVD Author 3.0.9.166 crashes on writing to disc
By gayclarke in forum Authoring (DVD)Replies: 4Last Post: 10th Oct 2007, 03:40 -
TmgEnc DVD Author Menu Problem
By powerkoala in forum Video ConversionReplies: 9Last Post: 25th Sep 2007, 13:19 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 19:43 -
Menu troubleshoot using Tmpgenc Dvd Author
By tekka06 in forum Authoring (DVD)Replies: 8Last Post: 4th Jul 2007, 03:53
