    Feb 2007
    My dvd's work fine after burning them however, the menu that I create only flashes on the screen for about a half a second, and then the screen goes white and you can kind of tell that the start button is there, after I press play on my remote it plays the dvd fine. It's not like I'm creating some complex menu either, I've just made a screen shot that I like for the background image, then make a "start" button, choose the silent sound for the sound option and add the menu to the job... can anyone tell me what is wrong, or what I'm doing wrong?
    Feb 2007
    oh, and I'm using the AVI2DVD by trustfm program just to clarify what avi2dvd program I'm using....
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    What software are you using ?
    How do you test it ?
    What are you playing it back on ?
    Have you tried it on other players ?
    Details, man, details.
    Read my blog here.
    Feb 2007
    well to convert, avi2dvd with HCEnc for the encoding, using nero to burn the vts files...playing it back on my dvd player, which is a JVC proscan, or my magnavox proscan, does the same thing on both and my power dvd program on my computer... flashes the menu screen for a split second..then goes blank
    Feb 2007
    anyone, anyone? bueller? bueller?
