Results 1 to 11 of 11
    Jul 2004
    I have read previous posts and cant find a solution
    stuck, have 20 small asf clips to put on dvd, but all the encoders say 3 of them are duff and they crash the programs, tmpge says "Index of scan line is out of range". Tryed video fixer with no luck, tryed asftools different combinations, no luck. Windows media encoder gets as far as the error and stops . The three bad ones however do play all the way through! its so frustrating.
    Is there anyway round this no matter how long it takes?
    Thanks for reading.
    Jul 2004
    i reckon the only way is the get svideo out lead from graphics card, into my tvcard and record it playing on my pc, then crop away?
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    In my experience, asf files are typically low quality, conversion will just decrease the quality a bit more. Is it really worth the time and effort, especially when the few tools capable of working with asf files are telling you the files are corrupt?
    EDIT: I believe one of the older versions of virtualdub worked with asf files.
    Google is your Friend
    Jul 2004
    Yeah trust me is very work it. They quality on a standard crt tv aint bad, and that was on 28" they basically wmv's arent they? just rename them? ill look for an early version of virtualdub and try that. thanks.
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    This is the version you want -> https://www.videohelp.com/tools?tool=Virtualdub_1.4c-ASF
    But I don't hold out a lot of hope.
    Read my blog here.
  6. Member Soopafresh's Avatar
    Jan 2004
    Here you go. You'll have to type a bit at the command line to set it up, but it'll work when other things won't.
    http://www.boutell.com/asftopipe/
    Easier would be guns1nger's method (there's your website name) - opening it in VirtualDub - VirtualDubMPEG2 v1.6 supports WMV , btw.
    Jul 2004
    1.3c wouldnt open v1.6 virtualdubmodmpeg is, im just gonna have a play with it now. thanks ppl. Be back later
    Jul 2004
    whehey 1 of the 3 files saved perfectly to uncompressed avi woohoo, im getting "unhandled replicated data length" with the other too. going to have a read now
    Jul 2004
    i hate command prompt so un user friendly, finally got asftopipe to do something, keep geting encoder errors though, no idea how to use it. Imjust gonna get svid cable lol
    Jul 2004
    DONE perfect DVD. All i needed was flashget! It downloaded the fastest and the file opened in EVERYTHING. I must have tryed 6-7 applications to download off the msn video mms urls. Flashget it the only one thats flawless for downloading Asf/wmv streams. So when someone next asks, you know what to tell them. thanks for all ypur help.
  11. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    How did flashget, a download program, help you convert asf files?
