  1. With this new age of online video and exporting in various file types, I've run it my misunderstanding of resolutions. My biggest question is about a setting in Premiere Pro - 720x480 Widescreen. How can it be widescreen 16:9 when 720x480 is a 4:3 ratio?
    What's the significance of 854x480? Anamorphic vs. Square Pixel?
    breaking news is my life...
  2. anamorphic is non-square pixel. So the video is "stretched" on display to 854x480 (which gives you 16:9 AR), because of the display flag
    Computer monitors have square pixels, so on display , the image has to be "stretched" to ensure the proper aspect ratio
    720x480 with square pixels gives you 1.5 AR, not 4:3
    720x480 with 4:3 display flag will playback at 640x480 or 720x540 (depending on media player), giving you 4:3
    720x480 with 16:9 display flag will playback at 853x480 (or 854x480 depending on media player), giving you 16:9
    For online video, everything should use square pixels 1:1 for compatibility. So you might resize 720x480 16:9 source to 720x400, for example. The AR will off a bit @ 1.8 vs. 1.778
  3. DAR = PAR * SAR
    DAR = display aspect ratio, the final shape of the picture
    PAR = pixel aspect ratio, the shape of individual pixels
    SAR = storage aspect ratio, the frame dimensions
    For example:
    DAR = PAR * SAR
    4:3 = 10:11 * 704:480
    4/3 = 10/11 * 704/480
    1.333 = 1.333
    16:9 = 40:33 * 704:480
    16/9 = 40/33 * 704/480
    1.778 = 1.778
