i can't get vc-1 to re-code is basically the head and tail of it... using tmpg enc 4 with shark codecs vc-1 loads up but in the view/cutting stage it has like white flecks in it?? super won't touch it.
This is a ripped m2ts, no problems at all with AVCHD m2ts files, anyone offer some advice? i did a search and came up with loads of stuff none of which was conclusive...
Results 1 to 18 of 18
Convert to what? ripbot264 or bd rebuilder to convert to mp4 or mkv.
doesn't bdrebuilder use directshow? tmpg does too so i'd say i might get the same result..? never tried ripbot but mp4 would be fine just don't want a 23gb file on the mediacenter!
i'm on a core i3 system does anyone know if it's DXVA related ?? maybe the VC-1 hardware acceleration doesn't work...
If you know your directshow configuration (what directshow decoder), you can test a script in avisynth with directshowsource() , and using graphstudio /graphedit
The VC-1 encoded blu-ray discs that commonly cause headaches are interlaced VC-1 , but those are rare (some discs like concerts use them) , even so you can use directshowsource() if you decode through the default windows wmv decoder . FFDshow's libavcodec cannot decode interlaced VC-1 correctly
I'm not sure what tmpgenc is using , but you can use other decoders (not dxva) if you use other methods -
i've tried selecting the two options for decoding the vc-1, one is windows media the other (libavcodec?) something along them lines neither plays properly.. tbh i've tried allsorts and am not particularly new to encoding but this has got me stumped!!
are your specs correct? winxp ?
do you have wmp11 installed ?
disable ffdshow decoding for vc-1 , and render the file in graphstudio , and see what decoder is being used?
how are you viewing/testing this ? through playback software (which one) or through tmpgenc ? It's possible tmpgenc is screwing things up
Do you see problems playing it back through playback software? e.g. mpchc -
w7, playback is fine thru pdvd9 it is only when i try to recode in the edit window/final cut it looks crap with white flecks in...
well i had a faff about yesterday and i'm unsure of which setting finally got me running... i'm pretty sure turning off dxva did the trick... 16hrs later still 7 hrs to go tho!!!
the recode went thru and 20hrs later i had a stuttery mess on mp4... any ideas on a better vc-1 recode (to mp4/avc) ???
the file in question is an m2ts bd rip vc-1 windows media won't play it although it will avchd m2ts so i'm guessing wm vc-1 codec won't cut the mustard...
I would try to remux from the m2ts file to a temporary MKV,
check if it plays fine in MPC-Homecinema,
then would create an appropriate Avisynth script for x264.exe
windows media won't play it although it will avchd m2tsWMP + Windows 7 = Media Foundation, NOT DirectShow.so i'm guessing wm vc-1 codec won't cut the mustard...
If there still exists a WMV9 DMO decoder in Windows 7,
"DirectShowSource()" will work as it should. -
What resolution are you encoding it to? Can you provide a small sample of the source ?
PSP encoding woes - chipmunks overruning the audio
By Cyntalan in forum Video ConversionReplies: 0Last Post: 27th Jan 2011, 20:48 -
YouTube Woes
By Nekias1 in forum Video Streaming DownloadingReplies: 16Last Post: 9th Oct 2009, 18:23 -
Podcasting Woes
By hellfire45 in forum AudioReplies: 3Last Post: 29th Sep 2009, 23:33 -
Resolution woes
By newsphotog in forum Newbie / General discussionsReplies: 2Last Post: 29th Sep 2009, 13:06 -
Nero woes
By turk690 in forum EditingReplies: 3Last Post: 13th Sep 2009, 18:27
