Results 1 to 11 of 11
  1. Member Googi's Avatar
    Aug 2005
    Canada
    Sorry if this is a repost.
    I had encoded an AVI in TMPGEnc and came out with a good, working, M2V File. After authoring my DVD, I played it on my DVD player (Philips DVP5960) and when tried to skip chapters or even scan forward or backward, the whole thing would freeze. I don't know if it is the M2V that's giving the problem or not.
    Apr 2004
    Miskatonic U
    How did you author it ?
    What software did you use ?
    Read my blog here.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    How as the audio created ? Poorly encoded audio can be almost as troublesome as poorly encoded video.
    Read my blog here.
  4. Probably missing sequence headers...
    We had the same discussion some month ago.
    See: https://forum.videohelp.com/viewtopic.php?t=281894
  5. Member Googi's Avatar
    Aug 2005
    Canada
    I have a MKV file that I extracted into 1 AVI, 2 AAC and one subtitle file, (I think SRT), to convert the audios, I used DBpoweramp to encode them into mp3 filess, then used ffmpeggui to encode the Mp3 files into AC3 files. is this acceptable?
  6. Yes. But check for missing sequence headers.
    Load your m2v file into a HexEditor or HexViewer and search for this byte sequence: 00 00 01 B3. You should find it a lot of times (at least once per MB)
  7. Member Googi's Avatar
    Aug 2005
    Canada
    How? can you suggest a program? and how am I supposed to use it?
  8. Member Googi's Avatar
    Aug 2005
    Canada
    If I change the Output Interval of sequence header to 1 GOP would that be good enough to fix my problem? what effect would a sequence header of >2 GOP have?
  9. ...Output Interval of sequence header to 1 GOP would that be good enough...
    Yes I think so. Maybe one sequence header for lets say each second or third GOP would also be sufficiant, but the DVD standard is one sequence header for each GOP.
