Closed Thread
    Oct 2009
    Mexico
    hello.
    i use mac the ripper 3 to rip my dvds.
    with some movies, when i drag and drop the video_ts folder into the "from" field, it appears that ffmpegx freezes trying to load the video. basically, it gets stuck with the pointer and the "+" sign (like it is trying to add the movie, but can't).
    i have to force quit ffmpegx and then restart it in order to move on to another file and i get stuck with movies i can't convert.
    is there a fix to this or a workaround?
    thanks,
    gcm
    USA
    mulgui, Do not post the same topic on several forums.
    Please do not cross post, once is enough.
    Continue in: https://forum.videohelp.com/topic374254.html#2013870
    Moderator redwudz
