When i start Svcd2dvd the splash screen appears but never go's once the program has started.
The program loads behind the splash screen and i can load Avi assets but as soon as i try to encode anything the program crashes with the errors below.
I have tried 2 versions of the program both have the same issue.
I have tried installing the program in other folders than progam files and also other hdds.
.netfix ok is installed as is also vbruntime.
The program has been running without a problem until recently.
My O.S. is Vista home premium 32 bit.
Here are the error reports
Version: SVCD2DVD 2.5
Build: 2.5.3300.0
Type: System.NullReferenceException
Source: SVCD2DVD
Message: Object reference not set to an instance of an object.
InnerException:
StackTrace: at x3284ccece41ee22b.xf42ff19ecf5d2596.x1ef984aa3cc71 762()
at x3284ccece41ee22b.xf42ff19ecf5d2596.x46438c7b1eac1 4ab()
at x3284ccece41ee22b.xd3764d4f1e921081.xf81783e1b359f fc3()
at x3284ccece41ee22b.xd3764d4f1e921081.x12cbe7a4e46ac 9ae()
at System.Threading.ThreadHelper.ThreadStart_Context( Object state)
at System.Threading.ExecutionContext.Run(ExecutionCon text executionContext, ContextCallback callback, Object state)
at System.Threading.ThreadHelper.ThreadStart()
Build: 2.5.3600.0
Source: SVCD2DVD
InnerException:
Please help me to sort this problem out as i have been using this program for a long time now without a problem and would like to continue to do so.
Best Wishes and Thanks to all who take the time to look at this thread..
RaM
Results 1 to 11 of 11
Can you post a log associated with this error?
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com -
Thanks for your reply Jikchung.
As far as i know there are no logs up until Svcd2dvd crashes when i try to encode the assets(apart form the error logs i have put in my post).
Unless there is another log being written somplace else,if so could you explain where this may be and i will post them. -
Look under the 'help' button.
Dwight
- Herm Albright
Sorry its taken me this long to reply.
Heres the log which is in the log folder once the program first loads with the frozen log screen.
************************ SYSTEM INFORMATION ************************
***************************** SVCD2DVD *****************************
Title: 2.5
Version: 2.5.3600.0
Executable: F:\SVCD2DVD v2.5n\SVCD2DVD.exe
Executable size: 2.57 MB
Executable size in bytes: 2703443
Executable CreationTime: 09/12/2007 17:41:26
Executable LastWriteTime: 25/02/2008 16:50:25
Executable LastAccessTime: 25/02/2008 16:50:24
************************* Operating System *************************
Operating System: Microsoft® Windows Vista™ Home Premium
Service Pack:
Version : 6.0.6000
Windows Directory : F:\Windows
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
Total Physical Memory: 0.99 GB
Free Physical Memory: 385 MB
Total Virtual Memory: 2.24 GB
Free Virtual Memory: 1.40 GB
***************************** Computer *****************************
Computer Manufacturer Name: VIA Technologies, Inc.
Computer Model: KT600-8237
System Type: X86-based PC
Computer Name: RAZOR-PC
DomainRole: x2c3419cdc9b8e007
Number Of Processors: 1
User Name: RaZoR-PC\RaZoR
***************************** Processor ****************************
Manufacturer: AuthenticAMD
Processor: AMD Athlon(tm) XP 3200+
Description: x86 Family 6 Model 10 Stepping 0
CPU Speed: 2.209GHz
CPU FSB: 201MHz
L2 Cache Size: 512 bytes
***************************** Time Zone ****************************
Time Zone: (GMT) Greenwich Mean Time : Dublin, Edinburgh, Lisbon, London
****************************** VIDEO *******************************
Name: Sapphire RADEON X1600 PRO
Processor: ATI Radeon Graphics Processor AGP (0x71C2)
Mode: 1440 x 900 x 4294967296 colors
Video Ram: 512 MB
Status: OK
Name: Sapphire RADEON X1600 PRO Secondary
Processor:
Mode:
Video Ram: 0
Status: OK
****************************** Drives *******************************
DeviceID: F:
FileSystem: NTFS
FreeSpace: 26.0 GB
DeviceID: G:
FileSystem: NTFS
FreeSpace: 36.2 GB
DeviceID: H:
FileSystem: NTFS
FreeSpace: 58.0 GB
********************* END OF SYSTEM INFORMATION ********************
************************* ProjectMetaData **************************
Many Thanks again.
RaM -
Is this after you hit the encode button?
Hi Chrissyboy
The log file is before I hit encode button but with the frozen splash screen.
Many Thanks Again
RaM -
Hi Again
Can anybody help with this problem, did i provide the right or enough information..?
Many Thanks
RaM -
Can you drop me an email and i will send you a build to try to see if we can get to the bottom of this...
Hi Again CrissyBoy
Many Thanks for that build.
Unfortunatley i get the very same problem only there is no error log with the frozen splash screen only after i hit the make a Dvd button.
Here are the Error reports that pop up in the Window when the prog crashes.
Build: 2.5.3800.0
Source: SVCD2DVD
InnerException:
Build: 2.5.3800.0
Source: SVCD2DVD
InnerException:
And this is the Error log
Title: 2.5
Version: 2.5.3800.0
Executable: F:\svcd2dvd\SVCD2DVD.exe
Executable CreationTime: 12/03/2008 09:02:36
Executable LastWriteTime: 28/03/2008 17:02:03
Executable LastAccessTime: 28/03/2008 17:02:03
Service Pack:
Version : 6.0.6000
OSLanguage: 1033
CodeSet: 1252
CountryCode: 44
Local: 0809
Free Physical Memory: 433 MB
Free Virtual Memory: 1.29 GB
CPU Speed: 2.208GHz
CPU FSB: 201MHz
Video Ram: 512 MB
Status: OK
Processor:
Mode:
Video Ram: 0
Status: OK
DeviceID: F:
FileSystem: NTFS
FreeSpace: 32.1 GB
DeviceID: G:
FileSystem: NTFS
FreeSpace: 29.6 GB
DeviceID: H:
FileSystem: NTFS
FreeSpace: 83.8 GB
Many Thanks Again.
RaM
Videos Freeze Up During Playback
By JohnnyGalaga in forum Software PlayingReplies: 5Last Post: 27th Oct 2011, 19:51 -
mpeg software causes freeze
By jaybravo in forum Newbie / General discussionsReplies: 0Last Post: 27th Aug 2011, 18:27 -
program freeze
By mulgui in forum Newbie / General discussionsReplies: 1Last Post: 12th Oct 2009, 22:03 -
mplayer freeze
By ajv in forum ffmpegX general discussionReplies: 2Last Post: 7th Jul 2009, 17:15 -
pc freeze up
By triggerstep in forum Video ConversionReplies: 5Last Post: 24th Feb 2008, 05:12
