Ok heres the deal. I got 4 shows. Each show has 4 files. I got a M2V, 2 AC3 files and a SRT per show. I load em all up in make chapters make pics (tho i have to say i made some ugly looking menus) When i got to burn it it says "No files to burn Actual DVD Dir C:.....". Whats up with that? I cant seem to find a good guide for this. I just need somthing very simple. On the title menu id like 4 links (one to each epp) And a play all key. Each epp page habe 4 links each to one of its chapter points with a picture for each. Id also like it to load one of the audio tracks by default and no subs. THat way if i wanna have the other audio track i just click audio on my dvd player, same for subs. Hope u can understand want i mean. Any help would be great![]()
Results 1 to 16 of 16
Just click 'CreateDVD' before you start to burn...
'Play all' is more or less 'default' if you set the end action to next movie in the project settings.GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
The thing is "create DVD" is grayed out as well
as It woult let me set it to NTSC. The option is grayed out and its on pal.
What kind of download did you use?
If the button 'CreateDVD' is grayed out, GfD could not find the path to the dvdauthor binaries. You can only set the video type (PAL/NTSC) at the start in GfD (before anything is added). If you want to make a "mixed" PAL/NTSC DVD you will be warned, but it is possible.GUI for dvdauthor:
Ahh ok. ty ill try to download it again and TY for the heads up on the pal thing
Ok i download DVD Aurther 0.6.11 and GUI 0.97.1 WHen i load up GUI_DVDauthor.exe and i go into setting to try and point it to the DVD Aurther exe but the thing is the file i download from the tool section does not have an EXE with it. Am i missing somthing?
Either use one of the install packages:
https://www.videohelp.com/~gfd/#Downloads
or the dvdauthor windows binaries version 0.6.12-alpha-2992-GfD-4:
https://www.videohelp.com/~gfd/edcounter.php?file=download/dvdauthor_winbin.zipGUI for dvdauthor:
This is gret. I got it to play and have duel audio and have subs. Lo0oks and sounds great. THo a new problem comes up. When ever i try to use fast forward or chapter jump the player will lock up. I tryed it on all 3 dvd players in my house all 3 do this. I cant even start from chapter 2 or 3. It only play with i start from the first frame. Im sure this is just somthing i forgot to do but what?
What happens if you use a soft player like PowerDVD, WinDVD or Media player classic? ATM I have no idea why your DVD behaves like this. I don't have NTSC material either, therefore I cannot exactly try to reproduce the error. The only thing I could offer you, is a closer look at the control files (the xml files and the saved GfD project file) and the log file, if you would send me these files (preferably as zip). My email can be found in the log file.
GUI for dvdauthor:
I've been having exactly the same problem with my encodes as well. I get the audio stream using VDubMod's full conversion mode (and convert it to AC3 using FFMPEGGUI), and feed the original avi to TMPGEnc with settings as suggested in this post to get the m2v file. Then I create the DVD with DVDAuthorGUI. Neither the m2v file nor the final DVD can be fast-forwarded, reversed or skipped (both on PC and stand-alone player). Since the m2v file behaves similarly, I'm guessing it's not the authoring program.Originally Posted by SPK8000LG
Any help will be greatly appreciated. Thanks in advance. -
As mentioned, I don't have these problems (both on PC and stand-alone player!).
Concerning the m2v file: Which player did you use? WMP is probably the worst choise for that purpose... Try it with VLC or MPC or a 'real' soft player like WinDVD.
If that should work (and it really should!) you could (at least for testing) try to author your streams with muxman. The multiplexing engine of muxman is deemed to be one of the best. In addition, muxman is very 'strict' concerning DVD standards.
BTW: The next version of gfd will support muxman (freeware version) as 'alternate authoring engine' with more or less the same functionality as dvdauthor (Multi-VTS, menus, buttons...) if really DVD compliant streams are used.GUI for dvdauthor:
I used MPC and it failed to fast-forward through the m2v file. I stupidly deleted the file though, so now I have to re-encode to try it on WinDVD. BTW, I use WinDVD to play the DVDs on the PC (which gave me same results).
Also, people using TMPGEnc to encode their files seem to have come up against this problem quite frequently:
https://forum.videohelp.com/viewtopic.php?t=192370&highlight=TMPG
https://forum.videohelp.com/viewtopic.php?t=233801&highlight=TMPG
https://forum.videohelp.com/viewtopic.php?t=200639&highlight=TMPG
https://forum.videohelp.com/viewtopic.php?t=239613&highlight=TMPG -
Ok. So it SEEMS to be any kind of encoding problem. Unfortunately m2v files are usually to big to be transferred (otherwise I would ask you to post/send an example), the first thing we should compare is the tmpgenc version and all settings. Maybe we can agree on some free source (trailer or similar) to use the same source also. I cannot believe, that this problem isn't solvable...
GUI for dvdauthor:
Excellent suggestion. To start off, I'm using TMPGEnc version 2.52.34.129. I'm attaching the last set of settings that gave me a messed up video file, in case it raises any red flags.
Anyone else up for it?
settings.mcf -
First results...
1. I use TMPGEnc Plus version 2.524.63.181 (Core version 2.04.169)
2. My 'testmovie' was/is the Hitchhiker's Guide Trailer (AVI version): trailer_hitchhikers.avi (can be found here: http://slashdot.org/articles/04/07/27/1231251.shtml )
This avi has 'similar' properties as your source (29.97 fps, 320*240, Divx v5) and is free.
For the first test I just copied your settings.mcf as a new template into my TMPGenc\Template folder and used it without any changes. The resulting m2v can be played with VLC and WinDVD (ver. 4.0.11.105) without any problems. MPC can play it, but freezes if speed is changed or skiped. Authoring the file with dvdauthor is possible, results are similar (MPC freeze, WinDVD no problem).
MuxMan cannot author the file and exits with the error: Multiplex operation failed, GOP contains more than 36 pictures at 213850 of (null)
3. I rerun the encoding with a standard template: DVD for NTSC 4:3 (North America and Japan), but changed the output type to ES (Video only). No other changes to the defaults. Result: No problems with any player/authoring engine.
4. I rerun the encoding several times by adjusting the standard settings to match yours more and more...
5. I rerun the encoding with your settings.mcf with only one change:
Tab: GOP structure
Output interval of sequence header: 1 (instead of 0)
=> It's the missing sequence headers that causes the problems.
(Which is 'understandable' as FF/skip usually 'jump' to a new position and need some infos about the new GOP)GUI for dvdauthor:
Which to use, DVDAuthorgui or "GUI for dvdauthor" ? Or DVDauthor in batch ?
By halsboss in forum Authoring (DVD)Replies: 2Last Post: 1st Feb 2010, 12:00 -
GUI for DVDauthor - error opening MMbackg.mv2 file
By PCH in forum Authoring (DVD)Replies: 27Last Post: 24th Jul 2008, 04:20 -
GUI for dvdauthor: The infamous SCR error.
By jedinix in forum Authoring (DVD)Replies: 5Last Post: 9th Mar 2008, 22:51 -
GUI for dvdauthor AC3 error
By rancid in forum Authoring (DVD)Replies: 6Last Post: 4th Jan 2008, 00:25 -
Need help w/ GUI For dvdauthor - Demuxed mpg throwing Discontinuity error.
By palouse in forum Authoring (DVD)Replies: 4Last Post: 15th Oct 2007, 19:33
