When I burn a dvd with Nerovision 3 how come the quality turn out terrible?
It's only one movie wich is about 3,5 GB.
But also when I put two different movies on one dvd
I want to reduce the quality because else the two movies don't go
on one dvd. But then the quality is as poor as when I put one movie on
dvd.
Should I use any other burning software? ( I've already tried UleadDvd but then
one movie is more then 4 GB! )
Results 1 to 30 of 52
Kate: What's the big thing that happens every Monday at one o'clock?
Tom: The dog outside the pub scratches itself...?
Kate: The plane from Broken Hill arrives! -
What is the original source?
He's a liar and a murderer, and I say that with all due respect. -
Sorry, but what do you mean with 'original source'?
You mean the movie file?Kate: What's the big thing that happens every Monday at one o'clock?
Is it an original DVD or a Divx/xvid file?
NeroVision isn't the best encoder out there. In the scheme of things, most people in the know wouldn't even rate it as serviceable. IMHO you'd be better off learning how to use TMPGEnc, CCE, MainConcept or even ConvertxtoDVD if one-click wonders are your game.Originally Posted by Flying Doctor
http://members.dodo.net.au/~jimaalenko/AVI2DVD.htm is a guide for using TMPGEnc Plus. There are other guides for the other softwares listed in the guides section to your right.If in doubt, Google it. -
The movies are in DivX format.Originally Posted by steveryanKate: What's the big thing that happens every Monday at one o'clock?
You need to learn about FitCD, avisynth filters, bitrates and encoding. Then you have half a chance of getting a half decent conversion. If you just want to trust your luck to software, use ConvertXtoDVD and put one to a disc.
Best solution for Divx/Xvid source - get a player capable of playing back Divx/Xvid encoded movies, and put 6 movies on a single DVD as data.Read my blog here.
Yes, but I need to play the dvd on a dvd-player. And ( if I make a dvd I try to do it perfect ) with a menu. When I burn a datadisc there is no menu. ( At least not as I want to )Originally Posted by guns1ingerKate: What's the big thing that happens every Monday at one o'clock?
So, you prefer lots of work, big quality loss and a menu to your liking, to no work, no quality loss and a simple menu/file selector?
I'm with Guns1inger.
/Mats -
Hi Flying Dutchman
TMPGEnc version 4 will take DivX input file and convert it to any output you want. Like one you need Mpeg2 DVD compliant to use on regular DVD player. Once you have file converted You will need other software to burn DVD, if you have Nero it will do. I used it with DivX and it works OK. TMPG also has subtitle editor, but it has some problem, like video will stop after few seconds of play in subtitle preview window, sound is OK. -
Oke thanx! I'm going to try that
The movies are converted to almost perfect quality, but when I burn with NeroVision it becomes poor quality again! ( On the dvd! )
Nerovision is reencoding your files .... you should be able to turn off the rencode feature of nerovision so that it burns the files as is (make sure they are dvd compliant mpegs) .... alternatively burn with a different app .... imgburn would be my choice ... its an excellent burning app, doesn't re-encode and best of all its free
So instead of NeroVision I should use IMGBurn? Can I create my own menu's in IMGBurn?
Oh and how do I turn of the reencoding program in NeroVision?Kate: What's the big thing that happens every Monday at one o'clock?
1. No you cannot create menus in imgburn
2. i don't know how to turn off the re-encode in nerovision (i don't use that software imo its crap)
3. if you are useing nerovision to create a menu then it will have to author a new dvd ... this could explain why it is re-encoding ... however it should be possible to create a menu and author the dvd without re-encoding the video ... again this is probably because the re-encode function in nerovision needs to be disabled
4, have you considered using TMPGenc dvdauthor to author your dvds ... this will allow you to create menu's and burn your dvd without re-encoding ... its not free though but there is a trial version you could try -
Oke thanks! I am going to try TMPGenc dvdauthor right now!
How do I invert my own background image?
And what is the best way to convert my videos? So TMPGEnc. is able to burn them?
Ow and, how do I burn to a dvd with TMPGEnc.?Kate: What's the big thing that happens every Monday at one o'clock?
TMPgenc dvdauthor is for authoring and burning dvds ... do not confuse this with the TMPGenc application ... which is for encoding
if you want perfect quality it depends on the quality of the original file if the quality is shit then its gonna be shit i use cce for my conversions i think it has to be the best software out there....then i use tmpgenc dvd author to make the menu you should give it a try heres the guide i use for cce https://forum.videohelp.com/viewtopic.php?t=222898
Right thanks! ( And I meant TMPGEnc DVDAuthor in my previous post )
But how do I invert my own background image? If I know that I can go
burning dvd's all day... :PKate: What's the big thing that happens every Monday at one o'clock?
What do you mean by invert? Turn upside down? Swap colors?
Anyway, that's hardly anything you'd expect the authoring app to do for you - do it in your graphics app before loading it into TDA.
...or do you mean insert?
/Mats -
To make a long story short, from my point of view, and alot of others, NeroVision 3 is NOT a true MPEG-2 encoder. And if you have content such as DivX or Xvid it should be converted into an MPEG-2 DVD compliant format before burning onto DVD, but don't use NV3 for that.
I use NV3 all the time for menus, and the final burn, and it's great for that, but my video has been properly encoded to MPEG-2 DVD compliant format BEFORE i load it into NV3.
The developers of NV3 made it an authoring software, but didn't focus on its encoding capabilities.
As well, in the More-->Video Options, enable "SmartEncoding" in NV3, as well as "Automatic" for alot of other features and of course "Fast Encoding (1-pass)" for Encoding mode. This way, if you have DVD compliant MPEG-2 material loaded into NV3, it will do minimal transcoding and should retain the quality on the final disc.
Think of a true MPEG-2 encoder as an awesome chef in a restaurant, and NV3 as your snazzy marketing consultant. Both will be great at what they do but will suck at reverse roles.
Then again, get a DivX certified player at Wal-Mart for under $50 and save yourself tons of headaches in the long run.I hate VHS. I always did. -
NV3 (and any real authoring tool) should not transcode compliant material at all. Any transcoding, even "minimal transcoding" is completely unacceptable. NV3 is not great at any of what it does. It is adequate in a small number of circumstances, but completely worthless for authoring material you have already correctly encoded.
Read my blog here.
Okay, so if I convert my DivX movie to MPEG2 ( with for example WinAvi ) and then open it in NV3 and then turn of the 'Smartencoding' etc. the quality remains good?
( Just checking :P )Kate: What's the big thing that happens every Monday at one o'clock?
Oh God. From NeroVision to WinAVI. It's like crawling out of the toilet bowl and into the sewer. WinAVI is known to produce non-compliant output. if you use WinAVI for your encoding then obviously quality isn't that high on your list.
Read my blog here.
Yes it is!
What videoconverter do you use then?Kate: What's the big thing that happens every Monday at one o'clock?
I did mean Insert...sorry!Originally Posted by mats.hogbergKate: What's the big thing that happens every Monday at one o'clock?
FitCD, avisynth and ProCoder, however you could use HCEnc to keep your costs at $0. You also need to use and understand a bitrate calculator, virtualdubmod and ffmpeggui so you can extract and convert audio where necessary. (I actually use Sound Forge for my audio conversion, but ffmpeggui will convert to 2.0 AC3 for $0). With the right combination of filters in your script, the results will be much better than anything WinAVI/Nerovision can ever produce. Of course, it takes longer, but quality always does.
Read my blog here.
I did turn off the smartencoding and choosed Fast Encoding (1-Pass ) but NV3 keeps encoding!!!!!!!!!!!
Poor Picture quality - need help!
By Martin747 in forum EditingReplies: 2Last Post: 26th Dec 2010, 12:00 -
Poor Burning Quality
By CindyLuB in forum DVD RippingReplies: 6Last Post: 17th Jul 2010, 20:41 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 19:23 -
Poor Video Quality
By itsernst in forum Capturing and VCRReplies: 20Last Post: 10th Feb 2010, 16:32 -
Poor Quality
By Net_Bug in forum Capturing and VCRReplies: 3Last Post: 29th Mar 2008, 16:37
