    Mar 2008
    Pakistan
    Hi,
    I have TV card of Pinnacle,
    when I plugged Cable into the TV it gives very good result but when I plugged the same cable in TVCard it gives poor result,
    I am attaching a link of captured clip, please check it & try to help me
    I want to capture videos in perfect quality.
    http://www.mediafire.com/?mtczmtzt4w8
  2. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    Looks like a poor signal on the cable. Check that the connection is tightly attached to your TV card. If you have any splitters, bypass them. Perhaps a signal amplifier could help.
    Most TVs and cable boxes have signal amplification, which could explain why the TV looks good, but the TV card doesn't.
    Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly.
    Mar 2008
    Pakistan
    But its working fine in TV,
    I have emailed this to technical support of pinnacle, they said I have 128mb buitin VGA card & I need to get seperate VGA card of 256MB then it will be ok.
    What do you think?
  4. A new video card isn't likely to help that problem.
    It's a noise issue. Check your grounding.
