Results 1 to 19 of 19
    Oct 2006
    Australia
    HI there
    I got this LG LCD TV up with component connection to dvd player, all the images become very green.
    I change to RGB ouput from my laptop to TV, when watch movie(like RMVB format) it also turns green.
    but if i change back to RCA(white, red, yellow cable) to watch dvd from normal DVD player(not from pc or laptop) it works perfect.
    I tested with RGB is because i am wondering what is wrong with this TV's digital video input?
    any thought?
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Originally Posted by sell_them
    HI there
    any thought?
    My thought is RGB DVD player to YUV makes green.
    Oct 2006
    Australia
    Could you explain more detail?
    I test RGB with laptop output, i think i proved it is green with digital video input?
    cause when I used component between HDTV lcd tv and dvd player, it turns green.
    is that my TV faulty or I configure or set up wrong?
    thanks
  4. Member edDV's Avatar
    Mar 2004
    thanks
    Many PAL (SCART) DVD players output RGB. Many LCD TV sets have YUV (aka analog component or YPbPr) inputs. The reverse could also be true depending where you bought your equipment. Some equipment can be set either way.
    Make sure you are outputing YPbPr to YPbPr or RGB to RGB.
    Another potential cause is a faulty cable.
    Laptop? Are you talking about VGA?
    Oct 2006
    Australia
    YEs, i am talking about VGA, use laptop to output to both laptop screen and LCD TV(as LCD mornitor). actually even look at the photo from laptop, all become green. other colour are normal.
    I changed to another component cable, it is the same, i did connect YPbPr to YPbPr(following the font on the socket, red blue and green cable between LCD tv and dvd player. it just becomes very green.
    My TV got default RGB port for use as computer monitor(connect normal monitor cable between them, i can choose from TV input to select your input RGB/DVI or component 1 or component2.
    just green. very annoying me.
  6. Member edDV's Avatar
    Mar 2004
    YEs, i am talking VGA, use laptop to output both laptop screen and TV(as mornitor). acutally even look at the photo from laptop, all become green. other colour are normal.
    I changed to other component cable, it is the same, i did connect YPbPr to YPbPr, red blue and green cable between LCD tv and dvd player. it just becomes very green.
    My TV got default RGB for use as computer monitor, i can choose from TV your input RGB/DVI or component 1 or component2.
    If VGA to VGA comes out green, you have a bad cable.
    Oct 2006
    Australia
    i changed VGA cable as well, even different laptop, it is the same.
    it is just all white or grey become very green, other colours are normal.
  8. Member edDV's Avatar
    Mar 2004
    TV make and model number?
    Oct 2006
    Australia
    LG 32inch 32LX2D LCD TV
  10. Member edDV's Avatar
    Mar 2004
    It seems to have all the inputs. Check the manual for what it will accept on the VGA port. Or call the LG support line.
    Oct 2006
    Australia
    what do you mean this?
  12. Member edDV's Avatar
    Mar 2004
    It should be a normal RGBHV computer port. It will work with a limited set of resolutions printed in the manual. 1366x768 is a flavor of WXGA.
    http://en.wikipedia.org/wiki/Wide_XGA
    Oct 2006
    Australia
    There are four Video type for my DVD player I can choose
    INTERLACE-YUV
    TV-RGB
    P-SCCAN YPBPR
    S-VIDEO
    If I changed to a very good S-video cable, this time it works, once I changed DVD player to play in S-Video mode,
    For component, it still goes green with "INTERELACE-YUV and P-SCAN YPBPR", if I chose S-VIDEO, it goes whole purple and white.
    But in back of DVD player it says PbPrY port,but for DVD player in the mannual it says it is CR/Y/CB output.
    any thought?
  14. Member edDV's Avatar
    Mar 2004
    INTERLACE-YUV
    TV-RGB
    P-SCCAN YPBPR
    S-VIDEO
    any thought?
    You are confusing me. We were talking about a VGA out from a laptop to the VGA port on the LCD-TV that was going green no?
    For DVD player to LCD-TV the better connection is progressive Y,Pb,Pr. This uses the Green-Blue-Red cable between the DVD player and the LCD-TV analog component inputs. The DVD player should be set to YPbPr progressive output and the LCD-TV should detect and display progressive video. This will be far superior to a S-Video connection.
    Oct 2006
    Australia
    Sorry, I mean not matter component or RGB (vga) output from laptop, it just turns green.
    red and blue are ok, just all white and grey turn to green colour.
    I couldnt find where to set up "The DVD player should be set to YPbPr progressive output and the LCD-TV should detect and display progressive video."
    there are no those configuration either in my dvd player or that LG Lcd TV.
  16. Member edDV's Avatar
    Mar 2004
    Try the "P-SCAN YPBPR" setting on the DVD player. Hook it up with analog component cable (Green-Blue-Red RCA).
    It is beginning to seem like you have a defective TV. It shouldn't turn green if you are following the manual.
    http://www.kiva.org/about
    Oct 2006
    Australia
    yES, i DID THAT "P-SCAN YPBPR" setting on the DVD player. Hook it up with analog component cable (Green-Blue-Red RCA).
    But how to set up TV with progressive mode, there is no option in manual for that LG
    Still green. i am thinking I got faulty TV.
  18. Member edDV's Avatar
    Mar 2004
    Call LG.
    Oct 2006
    Australia
    Thank you for your help edTV.
    I sent to LG service centre, after check, they said there is a problem with one accessory. Hopefully it can be fixed in one week.
    I cant believe it, i bought only for 3months, it already goes wrong.
