HI there
I got this LG LCD TV up with component connection to dvd player, all the images become very green.
I change to RGB ouput from my laptop to TV, when watch movie(like RMVB format) it also turns green.
but if i change back to RCA(white, red, yellow cable) to watch dvd from normal DVD player(not from pc or laptop) it works perfect.
I tested with RGB is because i am wondering what is wrong with this TV's digital video input?
any thought?
Results 1 to 19 of 19
Originally Posted by sell_them
Could you explain more detail?
I test RGB with laptop output, i think i proved it is green with digital video input?
cause when I used component between HDTV lcd tv and dvd player, it turns green.
is that my TV faulty or I configure or set up wrong?
thanks -
Make sure you are outputing YPbPr to YPbPr or RGB to RGB.
Another potential cause is a faulty cable.
Laptop? Are you talking about VGA? -
YEs, i am talking about VGA, use laptop to output to both laptop screen and LCD TV(as LCD mornitor). actually even look at the photo from laptop, all become green. other colour are normal.
I changed to another component cable, it is the same, i did connect YPbPr to YPbPr(following the font on the socket, red blue and green cable between LCD tv and dvd player. it just becomes very green.
My TV got default RGB port for use as computer monitor(connect normal monitor cable between them, i can choose from TV input to select your input RGB/DVI or component 1 or component2.
just green. very annoying me. -
i changed VGA cable as well, even different laptop, it is the same.
it is just all white or grey become very green, other colours are normal. -
http://en.wikipedia.org/wiki/Wide_XGA -
There are four Video type for my DVD player I can choose
INTERLACE-YUV
TV-RGB
P-SCCAN YPBPR
S-VIDEO
If I changed to a very good S-video cable, this time it works, once I changed DVD player to play in S-Video mode,
For component, it still goes green with "INTERELACE-YUV and P-SCAN YPBPR", if I chose S-VIDEO, it goes whole purple and white.
But in back of DVD player it says PbPrY port,but for DVD player in the mannual it says it is CR/Y/CB output.
any thought? -
You are confusing me. We were talking about a VGA out from a laptop to the VGA port on the LCD-TV that was going green no?
For DVD player to LCD-TV the better connection is progressive Y,Pb,Pr. This uses the Green-Blue-Red cable between the DVD player and the LCD-TV analog component inputs. The DVD player should be set to YPbPr progressive output and the LCD-TV should detect and display progressive video. This will be far superior to a S-Video connection. -
Sorry, I mean not matter component or RGB (vga) output from laptop, it just turns green.
red and blue are ok, just all white and grey turn to green colour.
I couldnt find where to set up "The DVD player should be set to YPbPr progressive output and the LCD-TV should detect and display progressive video."
there are no those configuration either in my dvd player or that LG Lcd TV. -
Try the "P-SCAN YPBPR" setting on the DVD player. Hook it up with analog component cable (Green-Blue-Red RCA).
It is beginning to seem like you have a defective TV. It shouldn't turn green if you are following the manual.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
yES, i DID THAT "P-SCAN YPBPR" setting on the DVD player. Hook it up with analog component cable (Green-Blue-Red RCA).
But how to set up TV with progressive mode, there is no option in manual for that LG
Still green. i am thinking I got faulty TV. -
Thank you for your help edTV.
I sent to LG service centre, after check, they said there is a problem with one accessory. Hopefully it can be fixed in one week.
I cant believe it, i bought only for 3months, it already goes wrong.
Intel GMA HD/Core i3 - VGA has TV-out/S-video-out/component-video-out?
By Morality124 in forum Media Center PC / MediaCentersReplies: 5Last Post: 9th Jan 2011, 00:44 -
RCA composite video on Wii but component video and VGA inputs on tv
By shashgo in forum Newbie / General discussionsReplies: 3Last Post: 22nd Aug 2010, 21:48 -
Component hookup to TV problem
By Noahtuck in forum ComputerReplies: 7Last Post: 20th Oct 2009, 18:03 -
Compatibility of composite video output VCR with component video input TV
By boshu22 in forum Newbie / General discussionsReplies: 7Last Post: 7th Sep 2009, 22:46 -
Component video signal->TV problem
By nathanaa in forum Newbie / General discussionsReplies: 3Last Post: 16th Jul 2007, 21:37
