Good morning.
I've tried to burn in a dvd, some VCDS I have.
Im trying to do that using TMPGenc dvd author, TMPGenc dvd PLUS and virtualdub. All tries without a success.
I Would like to unite (necklace) lots of VCD (650mb) video files in 1 DVD.
When I try to do that in those softwares, look what happen to me:
Can anyone help me?
Look the pictures:
Results 1 to 9 of 9
First, you need to look to the upper left for 'What is' DVD to see the DVD specification. VCD video should be DVD compliant, only the audio needs to be changed from 44Khz to 48Khz. Your VCD video is apparently not compliant.
A program like Gspot 2.52 can tell you the format of the video.
If it is not VCD or DVD compliant, you will have to re-encode it to the spec. Then you should be able to convert and author it to DVD. TMPGEnc DVD author can convert the audio from 44K to 48K. more or less automatically with compliant VCD video and audio. -
Hi red, thanks for the help..Originally Posted by redwudz
I tried Gspot and it says that my first video is a MPEG file and second (the one I would like to merge with the first video) is Non-AVI File - Type Unknown.
You told that DVD AUTHOR can re-encode for me, but how can I do that? is that simple?
I think I have to re-encode this VCDs.
Its very important for me, I have to merge these two files and its driving me crazy cause I've tried lots of software without a success!
So I would like to try the re-encode thing, and I would be happy with any help..
Well, thanks..
See if you can open it with VirtualDub Mod. If so you may be able to frameserve it to TMPGEnc encoder and re-encode it to compliant VCD format. Then you can use TMPEGnc DVD Author. DVD Author just converts the audio to 48Khz, it doesn't change the video. It will ask you when you drop it in. Frameserving guide: https://www.videohelp.com/tools?s=36#36 Frameserving sometimes works when TMPGEnc encoder won't accept the video directly.
to me it looks like the problem files are corrupt or at least non standard. Try the trial version of VideoReDo Plus and use the quickstream fix that is on the Tools menu, many times that will work.
You could try this tool https://www.videohelp.com/tools?tool=MPEG_Corrector
or https://www.videohelp.com/tools?tool=MPEG_Sequence_Maker
This second one is what I have used in the past for this kind of problem -
Hi TBoneit you are right, I've tried VideoReDo Plus and it fixed my problem with merging my FIRST and SECOND videos, BUT now I have a new problem.Originally Posted by TBoneit
I took a Fourth problematic video and I fixed it with VideoReDo, then I go to TMPGenc Plus to merge with a Third Correct video file.
Ok, when I try to merge these two files, TMPGenc Plus shows me the following error: "File does not have any video stream"
Does anybody knows how to fix it? What should I do? Whats wrong?
*PS: mods, feel free to move my post to another specific forum if im not posting in the right place, but please dont delete my post ok? Thank you very much and sorry for any inconvenience. thanks
Everything seems to point toward a corrupted MPEG file. Unfortunately there are not a lot of tools available to fix them. If you could open it in a player like VLC Media Player you might have a chance. If not, toss it and move on.
merge 2 subtitles files
By massimo.max in forum SubtitleReplies: 15Last Post: 29th Dec 2012, 02:35 -
How to merge avi files?
By mkvelidadon in forum Newbie / General discussionsReplies: 3Last Post: 26th Sep 2011, 02:25 -
Merge two FLV files
By goheadtry in forum Newbie / General discussionsReplies: 19Last Post: 16th Dec 2010, 21:34 -
merge mov files?
By Boru in forum MacReplies: 8Last Post: 29th Apr 2010, 23:43 -
merge two avi files
By Jorge in forum Video ConversionReplies: 4Last Post: 17th Feb 2010, 22:01
