Hello everyone
I recently got a hold of some old episodes of a cartoon I watches as a kid. The only problem is that each episode was two episodes, kind of like sponge bob etc...
What I would like to do is just merge them together without having to re encode everything.. Here is the data pulled from gspot.
VIDEO 1
--- File Information ---
File Name: 1.avi
File Name (with full path): C:\Documents and Settings\41i3n777\Desktop\1.avi
File Size (in bytes): 92,044,460
--- Container Information ---
Base Type (e.g "AVI"): AVI(.AVI)
Subtype (e.g "OpenDML"): OpenDML (AVI v2.0),
Interleave (in ms): 200
Preload (in ms):
Audio alignment("split across interleaves"): Split
Total System Bitrate (kbps): 0
Bytes Missing (if any): 0
Number of Audio Streams: 1
--- Video Information ---
Video Codec Type(e.g. "DIV3"): H264
Video Codec Name(e.g. "DivX 3, Low-Motion"): H.264/MPEG-4 AVC
Video Codec Status(e.g. "Codec Is Installed"): Codec(s) are NOT Installed
Duration (hh:mms): 11:52.080
Frame Count: 17802
Frame Width (pixels): 704
Frame Height (pixels): 544
Storage Aspect Ratio("SAR")" 1.294
Pixel Aspect Ratio ("PAR"): 1.000
Display Aspect Ratio ("DAR"): 1.294
Fields Per Second:
Frames Per Second: 25.000
Pics Per Second: 25.000
Video Bitrate (kbps): 867
MPEG-4 ("MPEG-4" or ""):
B-VOP ("B-VOP" or ""):
QPel ("QPel" or ""):
GMC ("GMC" or ""):
NVOP ("NVOP" or ""):
H264 ("H264" or ""):
Quality Factor (bits/pixel)/frame: 0.091"
MPEG-2 ("MPEG-2" or ""):
Interlaced ("I/L" or ""):
Progressive ("Prog" or ""):
Top Frame First ("TFF" or ""):
Bottom Frame First ("BFF" or ""):
3:2 Pulldown ("3:2" or ""):
Picture-per-field ("PPF" or ""):
--- Aspect Ratio Related ---
Broadcast standard: "PAL" (else blank)
Broadcast standard: "NTSC" (else blank)
src:"VCD", "SVCD", "CVD", or "DVD (else blank):
Instructions to convert to VCD, first part:
Instructions to convert to VCD, second part:
Instructions to convert to SVCD, first part:
Instructions to convert to SVCD, second part:
Instructions to convert to CVD, first part:
Instructions to convert to CVD, second part:
Instructions to convert to DVD, first part:
Instructions to convert to DVD, second part:
Instructions to convert to AVI, first part:
Instructions to convert to AVI, second part:
--- Audio Information ---
MPEG Stream ID (e.g. "0xbd"):
MPEG VOB file Substream(e.g. "0x80"):
Audio Codec (e.g. "AC3"): 0x0055 MPEG-1 Layer 3
Audio Codec Status (e.g. "Codec Is Installed"): Codec(s) are Installed
Audio Sample Rate (Hz): 44100
Audio Bitrate(kbps): 160
Audio Bitrate Type ("CBR" or "VBR"): CBR
Audio Channel Count (e.g. "2" for stereo): 2
VIDEO 2
File Name: 2.avi
File Name (with full path): C:\Documents and Settings\41i3n777\Desktop\2.avi
File Size (in bytes): 82,115,944
Preload (in ms):
Duration (hh:mms): 11:05.720
Frame Count: 16643
Fields Per Second:
Video Bitrate (kbps): 820
GMC ("GMC" or ""):
Quality Factor (bits/pixel)/frame: 0.086"
Let me give it a shot
thanks red. I guess they call you red because your Irish
Hey there
I have a small issue, I was able to get everything done. But I've seem to come across two videos that are not the same resolution, by 4 pixels
Is there some type of filter I can use to resize it?
Here is the info Gspot gave me.
VIDEO 1
File Name: 37. Dag's List.avi
File Name (with full path): C:\Documents and Settings\41i3n777\Desktop\Season 3\37. Dag's List.avi
File Size (in bytes): 101,823,390
Preload (in ms):
Duration (hh:mm
s): 11:46.800
Frame Count: 17670
Frame Width (pixels): 700
Frame Height (pixels): 576
Storage Aspect Ratio("SAR")" 1.215
Display Aspect Ratio ("DAR"): 1.215
Fields Per Second:
Video Bitrate (kbps): 985
GMC ("GMC" or ""):
Quality Factor (bits/pixel)/frame: 0.098"
Audio Sample Rate (Hz): 48000
VIDEO 2
File Name: 37. Daggy Dearest.avi
File Name (with full path): C:\Documents and Settings\41i3n777\Desktop\Season 3\37. Daggy Dearest.avi
File Size (in bytes): 111,316,354
Preload (in ms):
Duration (hh:mm
s): 11:05.720
Frame Count: 16643
Storage Aspect Ratio("SAR")" 1.222
Display Aspect Ratio ("DAR"): 1.222
Fields Per Second:
Video Bitrate (kbps): 1171
GMC ("GMC" or ""):
Quality Factor (bits/pixel)/frame: 0.116"
How to merge avi files?
By mkvelidadon in forum Newbie / General discussionsReplies: 3Last Post: 26th Sep 2011, 03:25 -
How to merge wav files ?
By Benjy in forum AudioReplies: 7Last Post: 31st Jul 2010, 05:41 -
merge mov files?
By Boru in forum MacReplies: 8Last Post: 30th Apr 2010, 00:43 -
Combine/Merge two avi files
By motherwell in forum MacReplies: 4Last Post: 28th Jan 2010, 16:45 -
How do I merge 2 .avi files? (using which software)
By Hank Kinsley in forum Newbie / General discussionsReplies: 3Last Post: 9th Jul 2007, 00:46
