I have a couple of movies that are split into two cds, and am interested in merging them into one avi file. I know there's plenty of software out there capable of doing so, I tried VirtualDubMod, but the issue being the video is merged according to run time, not actual frame count, resulting in frames being dropped. I hope you guys understand. I appreciate any help.
I don't know what you mean, but the usual method is to open the first segent in Virtualdub, then file/append the 2nd segment.
Set video and audio to "direct stream copy", file/save as avi. -
I used VirtulDubMod to append the cds, and that worked out fine. But what VirtualDubMod does is append the files according to the run time of the video, and I'm guessing milliseconds aren't taking into matter as you can clearly see on the result file that there are missing frames where the last disc ended. It doesn't shift smoothly onto the second disc.
It's supposed to include all the frames from both segments. If you drag through the timeline
after joining the files, do you see any anomalies at the join ?
I'm not sure what you're referring to when you said "according to the run time of the video".
Perhaps give Avidemux a try.
Is it possible to merge iso-files
By dazler in forum EditingReplies: 7Last Post: 6th Jan 2012, 04:29 -
merge two avi files
By Jorge in forum Video ConversionReplies: 4Last Post: 17th Feb 2010, 22:01 -
Combine/Merge two avi files
By motherwell in forum MacReplies: 4Last Post: 28th Jan 2010, 15:45 -
How can I merge two video files into one?
By DVDNewb in forum Newbie / General discussionsReplies: 24Last Post: 17th Mar 2008, 13:58 -
How do I merge 2 .avi files? (using which software)
By Hank Kinsley in forum Newbie / General discussionsReplies: 3Last Post: 8th Jul 2007, 23:46
