Is it possible to demux a DTS file to six WAV files? If so, how do I do it?
Results 1 to 30 of 44
http://sourceforge.net/projects/in-dtsc/
this is for dts cinema disks .. not sure it will work with dvd dts as that is a different type compression (you can try) , APT-X100 is the cinema type compression .. there is also a straight APT-X100 codec around ...
for dts off of dvd -- you can just use besweet with the azidts plug in http://www.videoediting.ru/files/azidts.zip and you have to have WinDVD installed"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
With that second plugin thing, can I just open the DTS file in BeSweetGUI then?
drop it into your besweet dir ..
and restart besweet .. file open xxxxxxxxx.dts (select dts as file source type)
now azidts will be shown in window below -- and select pcm as output and anything else you want to change"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
here is a pic
untitlef.jpg"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
another pic
untitlefff.jpg"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
click the folder icon next to the word 'input' and select dts from drop down list
There is no DTS option to choose and the there is no DTS decoder option on the right pane
post a pic - you must be using wrong version of something
that is the same version you had before
look in beta .... everyone uses the beta version ..
the stable version hasnt been updated in years"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
i think even the demo version will work
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 13:36 -
How can I make a .dts from wav's ?
By Robertus in forum AudioReplies: 2Last Post: 5th Jul 2010, 15:20 -
Some questions on converting DTS WAV files
By smackyourfupa in forum AudioReplies: 3Last Post: 17th Mar 2010, 09:04 -
Editing/Trimming a DTS Wav
By ranosb in forum AudioReplies: 12Last Post: 21st Jul 2009, 02:06 -
.wav and .dts file problems
By bskies in forum AudioReplies: 2Last Post: 20th May 2007, 03:23
