Hi everybody
I have a big problem, because i extracted wav's files from .dts
I edited a central channel(i changed and edited central channel from an ac3) and now i wish to make a .dts
Same lenght, 16bit, same MB(except central channel), but when i tried to make a dts with Surcode 1.0.23, new dts no sounds ( i tried to play it with vlc )
so i tried to make a dts from the original files(previously extracted and untouched), but the result is the same, dts no sounds.
maybe surcode is not good? i tried to use eac3to but i think that there isn't an option that make a dts from mono wav's files.
i hope in a reply, thanks in advance
bye
first older surcode versions were notoriously buggy, you should update to v1029. if that doesn't help try rtfm.
http://www.minnetonkaaudio.com/info/PDFs/Manuals/SurCode%20DTS%20DVD%20Pro%20Manual.pdf--
Hi,
Try to play your new created dts-wav file in power dvd[file mode]....if u can hear it....you're ok.If not try to encode the dts wav file in dts hd encoder suite[far better as surcode].
Enjoy,
M
How to use BeSweet or azidts to convert dts wav to mono wav?
By tcwillghsh in forum AudioReplies: 22Last Post: 28th Aug 2012, 14:36 -
convert dts 5.1 wav to ordinary mp3 etc.
By flannob in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2010, 06:02 -
Editing/Trimming a DTS Wav
By ranosb in forum AudioReplies: 12Last Post: 21st Jul 2009, 03:06 -
6-Channel Wav to AC3 and DTS
By kerpal in forum AudioReplies: 8Last Post: 9th Feb 2009, 10:10 -
.wav and .dts file problems
By bskies in forum AudioReplies: 2Last Post: 20th May 2007, 04:23
