    Jun 2004
    Melbourne, Australia
    Hi, I recently made a DVD disc with about 30 Music clips with a music menu on it. I'm very happy with the end result but there is one slight problem. Sometimes at the end of a video clip before it goes onto the next one there is a 30-45 second pitch black picture that appears on the screen. What could be causing this or what is it ??
    Any ideas.
    Thanks.
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Are all the clips in the same titleset?
    Jun 2004
    Hi ChrissyBoy, when i add the video clips i make a new VTS for each clip.
    So if i had 30 clips then i have 30 VTS. Should i just put the 30 in one VTS?
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    30 in one VTS would make them play seamlessly, but if they have wildly different properites then you may have some problems.
    I assume you are using the play all button on the menu? If so then at the moment after each clip you are coming back to the menu b4 going to the next clip. Different players will take different lengths of time to do this.... What is it like on the PC?
    Jun 2004
    ...but if they have wildly different properties then you may have some problems.
    Hey Chris, when you say wildly different properties, does this refer to the fact that i am mixing both Ntsc and Pal SVCD clips together on the one DVD, thus causing the problem?
    Yes i am using the play all button, so it doesn't go back to the menu after each video. I'll have to play it in my PC like you said and see if it still happens.[/quote]
  6. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Yes you need PAL and NTSC stuff on different TitleSets...
    Play All does in fact go back to the menu only you don't see it. But in terms of the actual delay it may still be significant.
