Hi, I recently made a DVD disc with about 30 Music clips with a music menu on it. I'm very happy with the end result but there is one slight problem. Sometimes at the end of a video clip before it goes onto the next one there is a 30-45 second pitch black picture that appears on the screen. What could be causing this or what is it ??
Any ideas.
Thanks.
Are all the clips in the same titleset?
Hi ChrissyBoy, when i add the video clips i make a new VTS for each clip.
So if i had 30 clips then i have 30 VTS. Should i just put the 30 in one VTS?
Thanks -
30 in one VTS would make them play seamlessly, but if they have wildly different properites then you may have some problems.
I assume you are using the play all button on the menu? If so then at the moment after each clip you are coming back to the menu b4 going to the next clip. Different players will take different lengths of time to do this.... What is it like on the PC?SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Hey Chris, when you say wildly different properties, does this refer to the fact that i am mixing both Ntsc and Pal SVCD clips together on the one DVD, thus causing the problem?...but if they have wildly different properties then you may have some problems.
Yes i am using the play all button, so it doesn't go back to the menu after each video. I'll have to play it in my PC like you said and see if it still happens.[/quote] -
Yes you need PAL and NTSC stuff on different TitleSets...
Play All does in fact go back to the menu only you don't see it. But in terms of the actual delay it may still be significant.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Black borders appears in DV video
By Fanda@CZ in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 13th Nov 2010, 03:39 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 18:36 -
Choppy or black video when rendering Digital Juice clips? - FCS2
By James in HD in forum MacReplies: 4Last Post: 19th Sep 2008, 09:29 -
Power DVD : picture hidden behind black screen???
By HBM in forum Software PlayingReplies: 2Last Post: 14th Sep 2007, 02:43 -
Screen goes black for half a second in Screen Virtuoso avi video stream.
By 2prfm in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 12:16
