i have a boxing match that was mpeg 2,,when i encoded the first time with h263 there was a lot of blocks in the picture,,so changed to mpeg using xvid btw and the picture came out really nice and smooth,,i always thought that h263 was better for encoding,,so what makes that difference between them,,thanks
Results 1 to 10 of 10
Do you mean h264?
And what converter and settings are you using? -
h.263 is meant for low quality, low bandwidth situations like old video phones.
no h263,,inside of xvids configs,,,so then using the mpeg quants is always better??i added a hard drive to my 360 or philips,,so am trying to shrink some stuff into xvids,,mainly dvds,,am using winavi and vdub,,because they offer alittle more than autogk does,,like bit rate control and sizing,,,anyway sorry to lead off topic there,,,so should i not use h263 anymore??stick with the mpeg quan then?
yeah but the h263 and the mpeg quants are encoding options within xvid,,and my philips isnt goin to play h264,,thats for high def isnt it?
You're talking about the quantization matrices in the Xvid codec. The MPEG matrix is a little sharper than the h.263 matrix. The MPEG matrix is more prone to macroblock artifacts because of this. You must have made some other changes if you see a big difference.Originally Posted by catdaddio6
so which one of those should i use?? when the h263 was used it looked like a bunch of squared pixel sections over the whole vid,,but was gone when went to the mpeg one,,thanks btw
If you want a sharper image with more macroblocks use MPEG. If you want a less sharp image with fewer macroblocks use h.263. h.263 does cause a little more macrblocking and posterization in smooth gradients.
As I said earlier, if you saw major differences in the amount of macroblocks something else was different, not just the matrix.
MP4 h263 amr NB
By Kowa1 in forum Video ConversionReplies: 3Last Post: 20th Apr 2011, 03:02 -
Mpg VS H263
By Anakin in forum Video ConversionReplies: 3Last Post: 9th Sep 2009, 21:24 -
Dvd to Mpeg4 h263
By molinman in forum Newbie / General discussionsReplies: 3Last Post: 5th Jan 2009, 17:13 -
exception when encoding h263 FLV files in JFLVTOOL
By icodeflex in forum Video Streaming DownloadingReplies: 1Last Post: 21st Oct 2008, 20:00 -
use 8x8 blocks with Sorenson H263 (FFMPEG)
By frifox in forum Video ConversionReplies: 1Last Post: 3rd Jun 2008, 13:58
