Hi!!
Have mobile phone Samsung which record and play only format as in title. Can't find any converter, muxer which can convert or combine h263 video and AMR NB audio in MP4.
Anybody have idea ???
Thanks forward.
You may want to start by converting your amr files to mp3's. A Google search on "AMR converter" found this one, among others:
http://www.amrtomp3converter.com/
I've used this and it has worked well. -
God, again
I am looking for any aplication which can from any other film ( no metter what format ) make film with this parameters
General
Complete name : D:\TestersCatalogue\Film-0001.mp4
Format : MPEG-4
Format profile : 3GPP Media Release 4
Codec ID : 3gp4
File size : 372 KiB
Duration : 21s 600ms
Overall bit rate : 141 Kbps
Encoded date : UTC 2003-11-07 00:00:00
Tagged date : UTC 2003-11-07 00:00:00
Video
Format : MPEG-4 Visual
Format profile : Simple@L1
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : 20
Duration : 21s 400ms
Bit rate mode : Constant
Bit rate : 128 Kbps
Width : 176 pixels
Height : 144 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Frame rate : 13.832 fps
Minimum frame rate : 7.463 fps
Maximum frame rate : 15.152 fps
Color space : YUV
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.365
Stream size : 334 KiB (90%)
Audio
Format : AMR
Format/Info : Adaptive Multi-Rate
Format profile : Narrow band
Codec ID : samr
Bit rate mode : Variable
Bit rate : 12.7 Kbps
Channel(s) : 1 channel
Sampling rate : 8 000 Hz
Bit depth : 13 bits
Stream size : 33.5 KiB (9%)
Writing library : Philips
This parameters above have film made by Samsung SGH-J700
amr to mp3
By aruwin in forum AudioReplies: 1Last Post: 14th Jan 2011, 12:37 -
Mpg VS H263
By Anakin in forum Video ConversionReplies: 3Last Post: 9th Sep 2009, 21:24 -
Dvd to Mpeg4 h263
By molinman in forum Newbie / General discussionsReplies: 3Last Post: 5th Jan 2009, 17:13 -
mpeg vs h263
By catdaddio6 in forum Video ConversionReplies: 9Last Post: 1st Sep 2008, 23:07 -
use 8x8 blocks with Sorenson H263 (FFMPEG)
By frifox in forum Video ConversionReplies: 1Last Post: 3rd Jun 2008, 13:58
