Ok, I just purchased an HD-PVR and it captures great quality via component cables but I can't figure out how to encode them to a .mkv file for personal use and to save space. I tried using DGMPGDEC152 to demux the file but I get this error.
I read posts her etelling me to demux it using DGIndex, then create a .avs file and then use mpegui to encode but I can't get past the first step. I also tried AutoMKV and get the same error. I tried Staxrip as well and I get a window called StaxRip - Log with the info in it and it has 3 options Jobs, Pause, and Abort. It also just stays at this screen.
Opening source files
C:\Users\Chris\Videos\test\2008_8_21_17_28_9.TS
General
Complete name : C:\Users\Chris\Videos\test\2008_8_21_17_28_9.TS
Format : MPEG-TS
File size : 21.4 MiB
Duration : 12s 692ms
Overal bit rate : 14.2 Mbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : Main@L4.0
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Duration : 12s 683ms
Width : 1280 pixels
Height : 720 pixels
Display aspect ratio : 16/9
Frame rate : 59.940 fps
Colorimetry : 4:2:0
Scan type : Progressive
Audio
Menu ID : 1 (0x1)
Format : AAC
Video delay : -50ms
Demux audio and index AVC using DGAVCIndex
"C:\Users\Chris\AppData\Local\StaxRip\Applications \DGAVCIndex\DGAVCIndex.exe" -i "C:\Users\Chris\Videos\test\2008_8_21_17_28_9. TS" -o "C:\Users\Chris\Videos\test\2008_8_21_17_28_9. dga" -a -h -e
Preparer: Demux audio and index AVC using DGAVCIndex
Start: 7:55:18 PM
End: 7:55:19 PM
Duration: 00:00:01
Results 1 to 30 of 224
I saw that already and I installed Haali Media Splitter and I can't find the program in the screenshot below. I'm also trying to convert the stuff to 29.970 or 23.976 like the MKV files I have .
You have 2 or 3 options:
1) Just straight remux the TS file to MKV with gdsmux. All the file properties are the same as the TS source
2) Feed the TS file to AutoMKV and configure it to whatever output format you want. Rename the extension from .TS to .M2TS if you get an error from AutoMKV
3) Leave the file alone and keep it at the glorious 720p settings it's already in. -
I renamed the file and still got the same error. Is there a guide to converting .ts files to .mkv and editing out commercials and making it 29.97fps or 23.976fps?
I edit my HD PVR TS files with h264ts_cutter.
I don't normally use MKV but to remux into MKV: Dumux the TS file with tsMuxerGUI then mux the two into an MKV file with MkvMerge (mmg.exe, included in MKVToolnix). Be sure to set the frame rate after adding the h.264 file to MkvMerge.
For IVTC or frame rate conversion I use DgAvcIndex, AviSynth (AvcSource()), and VirtualDub. If you want MKV you'll want to use something other than VirtualDub. -
Ok, I get this error in H264TS Cutter.
How do I set the bitrate for audio and video in mkvmerge? Also, I get this error in DGAVCIndex.
You can't. Mkvmerge just places things into the .mkv container.Originally Posted by Red Hat
You have to re-encode if you want to specify a bitrate or filesize. If so, then use jagabo's suggestions. Avisynth + DGAVCdec works on these clips. Another option is avisynth using DirectShowSource() which also confirmed to work. To edit visually you could use AvsP, and use Trim() to cut out commercials, etc., then feed it into an encoder. You would have to learn to use avisynth and basic scripting, but it's not that tough after after using it for a bit.
Your initial post mentioned DGMPGdec, which is for MPEG sources. DGAVCdec is for AVC sources, such as the HD PVR. If you chose this route, use Treat I as IDR setting (explained in the DGAVCdec user manual) -
In h264ts_cutter you have to mark segments you want to keep (Start and End buttons) then Add them to the cut list. When done, press the Cut button. The sections in the cut list will be saved to a new file.Originally Posted by Red Hat
I think you ran DgIndex, not DgAvcIndex.Originally Posted by Red Hat -
Ok, I tried DGAVCIndex and don't get that error. In H264TS Cutter, I got it working but I want the frames I select to be the ones I'm deleting not the ones I'm using because then I would have to make a bunch of .ts files and merge them. By the way, how do I make a avisynth file with the demuxed file from DGAVCIndex?
The program will automatically save all the cuts in the list as a single TS file.Originally Posted by Red Hat
Alright cool, but how do I get get the avisynth script with the demuxed file in DGAVCIndex then load it in megui?
AviSynth uses text scripts. You can create scripts with any text editor like Notepad. Name your script with the extension .AVS. The simplest script will look like:
filename.dga is the name of the index file saved by DgAvcIndex. Then you open the AVS script with your encoder. Not all encoders support AVS scripts. I don't know about megui.Code:AvcSource("filename.dga") -
I'm assuming you've edited with h264cutter, and are using DGAVCdec on the edited .ts
If you read the quickstart manual for dgavcdec (it's less than 1 page long), all you have to do is something like this: (you need avisynth, ffdshow, haali media splitter installed)
LoadPlugin("c:\PATH\DGAVCDecode.dll")
AVCSource("c:\PATH\FILE.dga")
(of course, you have to specify the correct paths&filenames)
You may want to deinterlace if it is interlaced
To IVTC, you can use TDecimate()
For the audio part, you need a script that serves your edited .ts file. You can use nicac3source() if it's AC3 audio. You could also use DirectShowSource("C:\PATH\FILE.ts", video=false) and plug that into the audio portion. If you are using MeGUI, it does audio & video separately, so you don't need audiodub(video,audio)
Cheers -
Ok, the audio is AAC and I want to open it up in VirtualDub and MeGUI. I have this in my AVS file so far.
It opens up in Virtualdub but no sound. -
AVCSource only specifies video, like i said earlier, you need to specify sound separately or use a script that does both.
VDub and MeGUI handle audio & video differently. You need it together for Vdub, and separate for MeGUI
You are missing the path for AVCSource
If you have 59.94 progressive (the other recording mode), then use
SelectEven().Decimate(5) -
Ok, but I can't load my audio in virtualdub because it's .aac and megui gives me errors when trying to encode.
The easiest way is just to use a simple script that specifies both. This is method#1 (doesn't need DGAVCdec)
DirectShowSource("C:\PATH\FILE.TS",fps=59.97,conve rtfps=true,audio=true)
This script specifies both video & audio, but you still have to enter the video & audio separately in each section in MeGUI, but you can use the same script. AAC has to be enabled in the ffdshow audio configuration for either method. You may need the directshow input driver for vdub.
For MeGUI, you have to setup the proper paths in the configuration before you start. There are several guides around (hit the guides button when you hit MeGUI in the tools section)
Fix your path if you are using DGAVCdec. You also have to specify audio if you are using this method, I gave a suggestion in an earlier post. This is method #2 (using DGAVCdec)AVCSource("Test.dga")
video=AVCSource("c:\PATH\FILE.dga").SelectEven().D ecimate(5)
audio=DirectShowSource("c:\PATH\FILE.ts",video=fal se)
Audiodub(video,audio)
If you want more help, be more specific on the errors that you're getting -
Alright, I'm set now. Thanks for all the help.
http://www.sendspace.com/file/s0pmex - Sample of my first MKV encode. I know I forgot to crop and define a language in audio but it's great. -
If the AVS script is in the same folder as the DGA file you don't need to specify the full path.Originally Posted by poisondeathray
Every fifth frame is a duplicate. Since it is a film source it should have been converted to 23.976 fps instead of 29.97.Originally Posted by Red Hat
Thanks jagabo, I never knew you didn't need the full path
I just noticed my typo fps=59.97 should have been 59.94 (if you used the 1st method), but I don't think that could explain the 29.97 (should have given 23.988)
You could also do the framerate conversion this way (or use DirectShowSource instead of AVCSource):
LoadPlugin("C:\PATH\DGAVCDecode.dll")
video=AVCSource("C:\PATH\FILE.dga")
Loadplugin("C:\PATH\TIVTC.dll")
video=ChangeFPS(video,29.97).TDecimate()
Saving space with MKV H.264 files
By Ahari in forum Newbie / General discussionsReplies: 269Last Post: 26th Apr 2013, 17:57 -
LaCinema Mini HD Connect cannot play MKV H.264 files ?
By centrino3 in forum Newbie / General discussionsReplies: 12Last Post: 12th Aug 2011, 09:45 -
How to edit .WTV files from Hauppauge HD-PVR (H.264/AC3) in Adobe Premiere
By milOtis in forum User guidesReplies: 2Last Post: 12th Apr 2010, 04:04 -
Accurately editing commercials from HD PVR h.264 .ts files
By finallygreen in forum Video ConversionReplies: 10Last Post: 28th Oct 2009, 14:14 -
Best way to convert/burn/play .mkv H.264 Blu-ray/HD DVD files on a Mac
By iMacMan in forum MacReplies: 7Last Post: 21st Mar 2009, 16:50
