ok but....
you're re-encoding the WHOLE file, nut just making a cut.
I don't see much of a point in capturing HD and then further recompressing the video with some other (VFW)codec.
btw VDubMod MKV mode is obsolete and not recommended by the MKV guys.
Results 211 to 224 of 224
Sorry, I had to go see about a girl
Problem is, if you just CUT certain portions, it goes out of sync.
The point of re-compressing the file is simple :
The capture is 10-15 GB.
Re-compressed file is 5-6 GB, same resolution, same quality, different codec. -
I managed to get this to work.
Tools used:
AviSynth 2.57
DGAVCDecode 1.0.8 (this comes with libavcodec.dll)
ffdshow-rev2280
VirtualDubMod 1.5.10.2
My version of the 1212 HD-PVR is D2.
I use the original version of Arcsoft Extreme. The update caused me problems.
Captured files are in .ts format with AC3 audio. I have had too much trouble with AAC.
I have done this with captures from the ArcSoft Extreme software and by using GraphEdit. Both work fine.
I hate to have to deinterlace, so I capture in 1280x720P 59.94 fps. I can tell NO difference in the quality between that and a 1080i capture at 30fps on my 42" Sony LCD. Also, using smaller resolution allows for a higher bitrate/file size.
First:
Open the TS file in DGAVCDecode/Index and >File>Save As and Demux> Note: Don't worry about the pid's. I always forget that step anyway.
Let it finish.
Second:
Point AviSynth .avs script to your .dga file.
My script is short and sweet and works.
LoadPlugin("C:\dgavcdec108\DGAVCDecode.dll")
AVCSource("mystream.dga")
This should be in the same directory as your .avs or point to it in full path and filename. I use another drive as a working/temp and keep all the files in the root partition. The less that my aging feeble mind has to deal with, the better.
Third:
Open VirtualDubMod and open the script.avs I call mine "mystream.avs This will load the video from avisynth
Click on the Stream button, and add the ac3 file that was demuxed from your original file. Don't worry about the delay listed in the file name.
Mine is typically 18ms stated in the filename, oddly enough it doesn't effect audio/video sync in the final output.
From here you can edit out commercials, trim or whatever.
Save As:
I select to save it as a .mkv. Full Processing Mode, ffdshow with .x264 at a bitrate about half of what the original was.....or less. I am still experimenting with the quality of output from here. I started with an abr of 4000 in ffdshow .x264 config
You can also configure your ffdshow output during the save as process if you need to. It looks kind of confusing, but it is actually very simple
Voila!!!
From HD-PVR .ts to .mkv.
Encoding time for a 42 minute capture (edited ahow) to a .mkv with x264 and ac3 with a final bitrate of 4000 kbps 1280x720 for a resulting file size of about 1.2 gig is about 4 hours on my Core 2 Duo powered HTPC @ 2.6 Ghz. WinXPpro SP2 2gigDDR2 80gig sys HDD 500 Gig storage. LG GH22LS30 Burner. This is my HTPC. My main rig is more of a heavy hitter. :P
The greatest part about this method is NO SYNC ISSUES WITH AUDIO!!!!! Not to mention the preservation of quality at a substantially smaller file size. Great for archiving.
I hope this helps.
If anyone plays with this method using .m2ts files with aac let me know, I am curious of the outcome.
Brad"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety." -
Essentially, this is the same as the method I posted above, only you use more steps to get there .....
Which one? You listed several. The steps I used are the steps I needed to accomplish the desired output. Which steps can I skip?Originally Posted by bc55
I meant this one. Just open your source file in VirtualDubMOD ( selecting DirectShow as the source ).Originally Posted by bc55
Then edit out the bits you don't want, choose compression, full processing mode, sync to audio and drop frames when behind and save the result as .MKV. -
I'll give it a go. If it will work for me I am all for a liberal application of the KISS principle.I meant this one. Just open your source file in VirtualDubMOD ( selecting DirectShow as the source ).
Cheers,
You're at the mercy of DirectShow when you do that. It may or may not work correctly depending on what file readers, file splitters, and decoders you have installed.Originally Posted by bc55
Yes I still have problems with it but I do have still some things I can try after reading this one.
But my problem is DGAVCDecode doesnt work for me. As my HD TS source file probably missing some data. Which isnt a problem for the transport stream itself as it is designed to deal with it but it causes sync problems as DGAVCDecode drops these parts.
My TS files itself plays fine but after converting (in various ways) them to mkv I always have sync problems. Though the first part is mostly fine its at the end that sync problems are acting up.
So if anyone has a way to deal with this I'm all ears -
Ok got things working, dont know if its the best way but at least its working for me now.
I make a graph for video with CoreAVC,
a graph for audio with ac3filter,
both are loaded in an avs file with DirectShowSource.
Seems a lot of people dont like DirectShowSource that much but its working for me quite well.
I cut out the commericals with AVS Cutter from MeGui. And put some other adjustments in the script.
Results are pretty nice. Whats left is playing around with filters and settings.
What are most used settings for 1920x1080 50i 13000 bitrating captures converted to 1280x720 25fps?
Im still trying to find a nice balance in quality and filesize.
Saving space with MKV H.264 files
By Ahari in forum Newbie / General discussionsReplies: 269Last Post: 26th Apr 2013, 17:57 -
LaCinema Mini HD Connect cannot play MKV H.264 files ?
By centrino3 in forum Newbie / General discussionsReplies: 12Last Post: 12th Aug 2011, 09:45 -
How to edit .WTV files from Hauppauge HD-PVR (H.264/AC3) in Adobe Premiere
By milOtis in forum User guidesReplies: 2Last Post: 12th Apr 2010, 04:04 -
Accurately editing commercials from HD PVR h.264 .ts files
By finallygreen in forum Video ConversionReplies: 10Last Post: 28th Oct 2009, 14:14 -
Best way to convert/burn/play .mkv H.264 Blu-ray/HD DVD files on a Mac
By iMacMan in forum MacReplies: 7Last Post: 21st Mar 2009, 16:50
