Hello, I want to re-encode AC3 audio from a mkv to AAC by applying a DRC in order to remove the differences between quiet and loud sounds. Do you know how to do this without having to re-encode the video part?
You can use ffmpeg for this.
btw it is not clear what are you mean by applying DRC - are you interested about signal dynamics processing to get similar loudness or to copy DRC metadata embedded in AC-3?
Also it may be important to get more details - for example if AC3 source is multichannel so downmixing must be performed to for example stereo or there is no downmixing required.Last edited by pandy; 12th May 2024 at 04:45.
If there's DRC metadata in the AC-3 it needs to be applied while it's being decoded. It's not all that spectacular though.
https://ffmpeg.org/ffmpeg-all.html#AC_002d3-Decoder-Options
As foobar2000 uses ffmpeg for most of it's decoding, buried somewhere in Preferences/Advanced you can specify a value for ffmpeg's drc_scale option. Rather than do that though, you can apply DRC with the Dynamic Audio Normalizer. It's included with ffmpeg and a bit easier to use than the official CLI version (ffmpeg is more GUI friendly). For DRC I'd normally add the following to an ffmpeg command line:
-af dynaudnorm=f=150:b=1
Or you could download this version of foobar2000: foobar2000 portable (for audio encoding)
You'll also need to copy ffmpeg to a specific location if you want to use any of the ffmpeg conversion presets. I'm pretty sure the zip file contains instructions on where to put things (it's been a while).
Load the audio you want to convert into a foobar2000 playlist, right click and select convert, and you'll see a Dynamic Audio Normalizer conversion preset. FFmpeg applies the DRC and from there the audio is piped to QAAC. There's also another "Compression" preset labelled LoudMax. It's a VST plugin. It's quite good although it only supports stereo audio. If I need to compress multi-channel audio for some reason I always downmix it to stereo first anyway.
You can open an MKV with foobar2000 and it'll play the audio within, but it doesn't account for any video or audio delay that might be present in the MKV, so when you mux the converted audio you should check to see if a delay needs to be applied. Or extract the audio first with gMKVExtractGUI so any delay will be written to the file name and convert the extracted stream instead. That's usually what I do.
[Attachment 79044 - Click to enlarge]Last edited by hello_hello; 12th May 2024 at 10:29.
Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview)
AC3 to AAC
By BlurayHD in forum Newbie / General discussionsReplies: 17Last Post: 25th Feb 2023, 09:34 -
AC3 5.1 to AAC 5.1
By shazzla in forum AudioReplies: 4Last Post: 24th Aug 2021, 05:53 -
AAC 360 is AC3 how much?
By JosephTocco in forum Newbie / General discussionsReplies: 1Last Post: 25th Feb 2021, 16:17 -
AAC or AC3
By JosephTocco in forum Newbie / General discussionsReplies: 7Last Post: 13th Feb 2021, 10:29 -
Converting eac3 to aac and ac3
By dbzbleach in forum AudioReplies: 1Last Post: 5th Jan 2020, 00:22
