I have been using the latest version of avisynth 2.6 for many years now. I did not wish to update my avisynth because it was not broken and worked perfectly for everything I wanted to do pretty much.
Well it's beginning to get really out of date and I cant work on HDR, or 10-bit things or use 64-bit avisynth stuff with it.
I uninstalled avisynth 2.6, and I installed the newest AviSynthPlus_3.7.3_20230715. I put my plugins I was using in the older version into the plugin folder of the newer avisynth+ installation and I restarted my computer.
This appears to have broken AvsPmod and it not longer works. I get a bunch of errors about an N character or something. I found out I needed to update that as well so I got a newer AvsPmod_v2.7.6.5_.Windows_x86-32. It opened up without all those errors and seemed to work, but I have a problem now. AvsPmod doesnt work right anymore.
Every time I try to load up a script, it just says "Waiting for avisynth clip" and then it stays like that forever.
In the older AvsPmod and older avisynth 2.6, I could paste that script and it INSTANTLY loaded up and worked great. Whats going on here and why cant I use AvsPmod anymore? I should not have to be waiting for hours to infinity for a clip to load.
I don't even have anything in the script except a basic loader and a preview wont ever even load up.
Code:LoadPlugin("C:\Users\Admin\Desktop\MeGui\tools\ffms\ffms2.dll") FFVideoSource("C:\Users\Admin\Desktop\Encoding\TL\00009.mkv", threads=1)
Whats going on?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 17 of 17
If you open AvsPmod and use the File/New Tab menu and type Version() into the new script, does it show in the preview?
If it does, maybe you need to update some plugins. Put FFMS2.dll from here into the auto-loading plugins folder and delete the first line from your script above, so it's not using MeGUI's version of FFMS2 to open the video.
https://codeberg.org/StvG/ffms2/releases/tag/r1391
You might need to update quite a few plugins anyway, especially if you're using old plugins that only support 8 bit video.
Are you using a 64 bit version of Windows? If so, pretty much all the common plugins now come in a 64 bit flavor, so if you have to update
plugins anyway, I'd consider installing the 64 bit version of Avisynth+ and AVSPmod, and updating to 64 bit plugins while you're at it.
There may be an old plugin in the auto-loading folder that doesn't play nice with Avisynth+, so you could try removing all the plugins from the auto-loading plugins folder (except FFMS2) to see if Avisynth+ will then run.
When you installed Avisynth+, did you install the version that includes the runtime files (vcredist)? If not, try re-installing it using that version. Some newer plugins require them too.
https://github.com/AviSynth/AviSynthPlus/releases
And I assume you know everything has to be either 32 or 64 bit, Avisynth+, plugins and AvsPmod. If you install Avisynth+ 64 bit it should add plugins64 and plugins64+ folders. 32 bit plugins go in the plugins or plugins+ folders, assuming you have the 32 bit version of Avisynth+ installed. You can install them both at the same time, but you can't use 32 bit plugins with 64 bit Avisynth (or the other way around).Last edited by hello_hello; 6th Jan 2024 at 03:21.
Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview) -
No it does not. It does the same thing. It says "waiting for avisynth, thread still running" and it just stays stuck like that forever and does nothing. I waited for 2 hours just to see if it would do anything and it never changed.
https://i.imgur.com/3gceRwz.png -
I'd try again without any plugins in the auto-loading plugins folder.
I did it with a fresh install of avisynth and no plugins except the defaults AVISynth+ comes bundled with, and its doing that same thing in AvsPmod.
I even tried disabling what I read here and it did not fix it for me.
https://forum.videohelp.com/threads/404797-help-with-avspmod -
No, it opens a .avs file that has nothing but version() in it just fine from the looks of it.
If I try to load the video that I tried in my original post, it throws out an error.
After I select OK 2 times, then it actually loaded the video. I could seek through it and look at it.
AvsPmod however has that issue I stated above and will just freeze forever while saying waiting for avisynth, no matter what is in the script. MeGui just locks up all together when trying to load videos, it doesn't work either.Last edited by killerteengohan; 6th Jan 2024 at 18:32.
If it works in vdub2, then avs+ must be ok - and there is some issue your megui and avspmod
https://i.imgur.com/50kGUuH.png
Try running avsinfotool to see if there are any other clues -
I think in order to use MeGUI with newer Avisynth+ versions, the AvisynthWrapper might need to be updated.
https://drive.google.com/file/d/1JfiokTy2IOqOn1VTXN0eXQEDCC3vUdN4/view
Having said that, if MeGUI is configured to always use the included Avisynth in it's options, the installed Avisynth shouldn't have an adverse effect on it. MeGUI has been using Avisynth+ for it's portable Avisynth for quite a while, although I think it's using an old version, probably 3.5 or thereabouts.
I've updated MeGUI's Avisynth+ so it's using a newer version, but the log file will tell you if it's using it's portable Avisynth and which version it is.
VirtualDub2 has an OpenCL option under Display in Preferences. Maybe check it's not enabled.Last edited by hello_hello; 7th Jan 2024 at 14:01.
I wonder if some of these apps check to see if openCL is active in the system, and something in the setup/enumeration is broken?
Check this for a quick way to turn openCL support on and off.
https://community.intel.com/t5/OpenCL-for-CPU/Uninstall-Intel-OpenCL-Platform/m-p/1109710
I don't have this on my PC because I'm using motherboard GPU and it's not supported. If I had a real GPU,
support would have been installed by the driver
Before reinstalling the driver, probably worth running the system file check from the Admin command prompt:
Code:sfc /scannow
avsinfotool doesnt work for me. It opens up then freezes on "please wait" and the program never responds or does anything, so I have to end AvisynthInfo32.lib process in task manager to be able to do anything in it.
If I end it, and manage to switch to the 64-Bit button I get this.
The 32-bit button just refuses to work. This is possibly an issue since its 32-bit avisynth I am trying to use in my encoder.
I installed both 32-bit and 64-bit versions of avisynth+, so why the 32-bit wont work I don't know.Last edited by killerteengohan; 10th Jan 2024 at 23:20.
vcruntime140 is associated with the Microsoft VC redististributable, you can download/install/update/fix them from here:
https://learn.microsoft.com/en-us/cpp/windows/latest-supported-vc-redist?view=msvc-170...-2019-and-2022
avisynth/AvsPmod macro/function to append videos
By Marc1973 in forum Newbie / General discussionsReplies: 2Last Post: 29th Apr 2023, 01:27 -
QTGMC not working properly (AviSynth+)
By JadHC in forum RestorationReplies: 12Last Post: 15th Feb 2023, 18:18 -
Avspmod stopped working
By Smart Jason in forum Software PlayingReplies: 4Last Post: 16th Nov 2019, 05:54 -
SRestore not loading/working with AVISynth
By Fraugster in forum EditingReplies: 11Last Post: 11th Aug 2019, 21:05 -
QTGMC/IVTC issues on AVISynth/AvspMod
By Fraugster in forum RestorationReplies: 33Last Post: 7th Aug 2019, 08:55
