  1. hi, I've recently reinstalled and updated avisynth, all the plugins and avspmod.
    it seems all working like before, till now, except for when I use the command "Prefetch(n)".
    doesn't matter what number I use, as soon as I reload the script, a little window appears,
    saying "Waiting for avisynth, thread is still running", and apparently it never stops.
    It gets stucked for ever.
    it never happened before the reinstall.
    can I please have some help?
    https://www.dropbox.com/s/54xaepz8g9gxrox/prefetch.png?dl=0
  2. Update avs+ to 3.72 test 3, and the newest avspmod, and/or disable frame properties
    https://github.com/gispos/AvsPmod/releases
    Avisynth 3.71 final version has problems with prefetch and frame properties. **
    AvsPmod also reads the frame properties when creating a clip, so avisynth hangs.
    There are two ways to avoid this:
    Video > Display > YUV -> RGB > 'Read from source or script' must be disabled.
    or
    Use Avisynth version 3.72 test 3, the problem was fixed here.
    https://forum.doom9.org/showthread.php?t=181351
  3. thx for the info dude.
    or
    I disabled the 'Read from source or script' and it no longer hangs on Prefech.
    But did I disabled a function that I need?
    what does disabling that function involve?
    is it better to keep it enabled while upgrade to Avisynth version 3.72 test 3?
  4. It's just for the YUV to RGB preview in avspmod
    avisynth reads and passes "props" like metadata flags now, if the source filter passes it - such as matrix, primaries, transfer, field order etc.. - and avspmod can use those to adjust the RGB conversion for the preview automatically. For example if file was flagged bt.601, it would auto adjust.
    It's up to you ; personally I leave it as "resolution based", progressive, TV levels - because I'm used to the old way . If I need to convert to RGB in a specific manner, I specify the specific arguments in the script. Moreover, some files are flagged incorrectly. Doing it manually (at least for me) is another layer of checking for errors
  5. hi, sry about this, I had a problem with colors corrections, but now is all fine, I made a mistake. sry
