We're still in lock down so I was hoping to use the time to create some edited movies for personal use. I want to integrate deleted and/or additional scenes between various versions (like theatrical, extended, unrated, directors cuts etc).
I am editing the 1979 Theatrical version of Alien. It is 16:9
I also have the Directors cut disc and I want to take two scenes from the DC and add them to the theatrical cut to create my own personal cut. The DC is 2.35:1.
I used VideoRedo to cut the various scenes that I want
When I started the join the video ended up with a black bar that takes up 50% of the screen. I'm guessing that's because the scenes are at different resolutions.
I tried using MKVToolNix but that didn't work.
Is there a way I can convert my DC disc to 16:9 so I can complete my personal cut?
EDIT: I used xMedia Recode to change resolution. Playing that re-encoded section looks perfect with potplayer, but as soon as I join it with VideoRedo the black bars are gone and image stretched for the DC scene and present in the theatrical scene.
Clearly I have no clue what I'm doing, but I want to learn
Results 1 to 10 of 10
10940x with Creator X299 Motherboard, 32GB DRR4-3733, RTX 3080 Ti GPU -
Alien (1997) has an AR of 2.39:1 according to IMDB, so the 16:9 version (if it doesn't have black bars) is cropped. To insert a part of the DC you have to crop it and maybe resize it to the same resolution as the TV (you don't write anything about the resolution of the two movies).
So if your TV version has a resolution of 1280x720 (16:9) and your DV version has a resolution of 1280x536 (2.39:1), then you have to cut out an area of 954x536 (16:9) from the DC image and resize it to 1280x720. The framerate of the two movies must of course also be the same. This is only possible with re-encoding.
Then you can merge the two parts with Videoredo.
For the encoding part you can use my clever FFmpeg-GUI.Last edited by ProWo; 25th Jan 2021 at 03:15.
Here's the resolution information for each file.
Both unedited versions have black bars.
Theatrical version
Directors CutCode:Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 3 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 3 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1 h 56 min Bit rate mode : Variable Bit rate : 26.3 Mb/s Maximum bit rate : 40.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.529 Stream size : 21.4 GiB (98%) Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.25 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-4 / threads=12 / lookahead_threads=2 / sliced_threads=0 / slices=4 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=1 / constrained_intra=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=1 / weightp=0 / keyint=24 / keyint_min=1 / scenecut=40 / intra_refresh=0 / rc_lookahead=24 / rc=2pass / mbtree=1 / bitrate=26292 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00 Default : Yes Forced : No
Code:ideo ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 5 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 5 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1 h 55 min Bit rate : 12.1 Mb/s Width : 1 920 pixels Height : 817 pixels Display aspect ratio : 2.35:1 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.322 Stream size : 9.81 GiB (78%) Encoding settings : cabac=1 / ref=5 / deblock=1:-1:-1 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=48 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=25 / lookahead_threads=4 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=17.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Default : Yes Forced : No
Can you provide a short video sample of both versions? 10 -15 seconds should be enough
Crop the 2.35 movie like this:
Left 236, top 1, right 236, bottom 0.
This gives an resolution of 1448x816. Resize this to 1920x1080 and encode to new video.
With my clever Ffmpeg-GUI this can be done easely.Last edited by ProWo; 31st Jan 2021 at 15:56.
alien 1979 was always 240/1. what have you got, some cropped tv version of the movie? you're missing a lot of the visible part of the film i'd get the real thing and then there won't be any issue between the 2 versions.
Yanta, do you use Avisynth at all? If not, there might be too much of a learning curve, but if you already know Avisynth it's pretty easy. Post back to let us know if you've used Avisynth and if you're happy to re-encode both videos. I'd resize both to 1280x720 so the director's cut doesn't need to be upscaled after it's cropped to 16:9, use Avisynth to select the frame ranges from each video you want to encode, join the sections together in a script and encode the whole lot as a new video.
By the way, if the Director's cut is standard YV12 video, the height must be a multiple of two, so 817 pixels is theoretically impossible. Has it been encoded to another color format?Avisynth functions Resize8 Mod - Audio Speed/Meter/Wave - FixBlend.zip - Position.zip
Avisynth/VapourSynth functions CropResize - FrostyBorders - CPreview (Cropping Preview) -
@hello_hello. I've never used avisynth. I'm just starting out and have a lot to learn.
@aedipuss: The disc was one I got from my brother who got it from a $2 store. It's very hard to find (at least, not paying $40 or more)
@ProWo: I'll give it a go. It crashes. See below..
@davexnet: Attached (hopefully). These were both cut at 00:03:00 - 00:03:10
Clever FFMpeg-Gui..
Code:See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.ComponentModel.Win32Exception (0x80004005): The system cannot find the file specified at System.Diagnostics.Process.StartWithCreateProcess(ProcessStartInfo startInfo) at clever_FFmpeg_GUI.Module1.ShowVideoTracks() at clever_FFmpeg_GUI.Form2.Show_Tracks() at clever_FFmpeg_GUI.Form2.Button2_Click(Object sender, EventArgs e) at System.Windows.Forms.Control.OnClick(EventArgs e) at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) at System.Windows.Forms.Control.WndProc(Message& m) at System.Windows.Forms.ButtonBase.WndProc(Message& m) at System.Windows.Forms.Button.WndProc(Message& m) at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) ************** Loaded Assemblies ************** mscorlib Assembly Version: 4.0.0.0 Win32 Version: 4.7.3690.0 built by: NET472REL1LAST_C CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll ---------------------------------------- clever FFmpeg GUI Assembly Version: 1.0.0.0 Win32 Version: 2.7.1 CodeBase: file:///H:/ffmpeg/clever%20FFmpeg%20GUI.exe ---------------------------------------- Microsoft.VisualBasic Assembly Version: 10.0.0.0 Win32 Version: 14.7.3190.0 built by: NET472REL1LAST_C CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll ---------------------------------------- System.Windows.Forms Assembly Version: 4.0.0.0 Win32 Version: 4.7.3690.0 built by: NET472REL1LAST_C CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll ---------------------------------------- System Assembly Version: 4.0.0.0 Win32 Version: 4.7.3640.0 built by: NET472REL1LAST_C CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll ---------------------------------------- System.Drawing Assembly Version: 4.0.0.0 Win32 Version: 4.7.3190.0 built by: NET472REL1LAST_C CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll ---------------------------------------- System.Configuration Assembly Version: 4.0.0.0 Win32 Version: 4.7.3630.0 built by: NET472REL1LAST_B CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll ---------------------------------------- System.Xml Assembly Version: 4.0.0.0 Win32 Version: 4.7.3190.0 built by: NET472REL1LAST_C CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll ---------------------------------------- Accessibility Assembly Version: 4.0.0.0 Win32 Version: 4.7.3190.0 built by: NET472REL1LAST_C CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll ---------------------------------------- System.Runtime.Remoting Assembly Version: 4.0.0.0 Win32 Version: 4.7.3190.0 built by: NET472REL1LAST_C CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll ---------------------------------------- ************** JIT Debugging ************** To enable just-in-time (JIT) debugging, the .config file for this application or computer (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the computer rather than be handled by this dialog box.Last edited by Yanta; 4th Feb 2021 at 02:22.
You'll probably get some other suggestions, but this is my first thought. Simply crop the top and bottom of the theatrical cut
to match the other, then join them:
Then encode in Virtualdub2Code:thv=lwlibavvideosource("C:\Users\davex\Desktop\ALIEN.Theatrical (1)-002.mkv") thaud=lwlibavaudiosource("C:\Users\davex\Desktop\ALIEN.Theatrical (1)-002.mkv") thv=crop(thv,0,140,-0,-140) dcv=lwlibavvideosource("C:\Users\davex\Desktop\Alien (1979) - 1080p [Directors Cut] (1)-002.mkv") dcaud=lwlibavaudiosource("C:\Users\davex\Desktop\Alien (1979) - 1080p [Directors Cut] (1)-002.mkv") th = audiodub(thv,thaud) dc = audiodub(dcv,dcaud) th ++ dc -
Try with the newest beta:
https://files.videohelp.com/u/292773/clever_ffmpeg_gui_newest_beta.7z
