I have VLC 0.8.6 installed.
I have tried to play Divx's with 5.1 ac3 ....and
DVDs with 5.1 Ac3 soundtracks.
But it doesnt work!!
I just get a kind of pulsing sound when I select the
A/52 over SPDIF!!
I can play stereo option.
I have my motherboard/onboard sound connected via optical link
to my 5.1 surround sound amp.
I can get 5.1 Ac3 sound output via this link
when using media player classic 6.4.9
and zoom player 5!!
But for some reason all I get when I try and select
A/52 over SPDIF...as I said ...is a kind of pulsing noise.
its almost like the soundtrack is out of phase/sync...
Its so annoying ...anyone have suggestions or tips to fix this?????
TIA Aussiemac
Have you tried this?
Go to [Preferences] and check [Advanced Options]
Then Expand [Audio] and select [Output modules]
Change [Audio output module] to [Win32 waveOut extension output]
Then click on [Save] and quit and re-start VLC
Try SPDIF output after all that and hopefully it should work. -
The Easter bunny has delivered early!!!....Thank you!!!
This little problem has been round for awhile ...
and never... could I change a
setting to beat it....then low and behold!! ....in a religious spirit ...hehe!!
the solution is ...delivered!!...like a good batch of hot cross buns!!
We have sound from all six speakers....and it aint no pulsing noise!!
Thanks again...
Aussiemac
VLC Player's "record" feature- can I change the output folder?
By gastrof in forum Newbie / General discussionsReplies: 1Last Post: 29th Mar 2012, 23:32 -
spdif output hack to input?
By tsantsa in forum ComputerReplies: 4Last Post: 31st Oct 2008, 00:59 -
[VLC] AC3 video file + spdif output = stereo?
By SANAFABICH in forum Software PlayingReplies: 0Last Post: 10th Aug 2008, 16:59 -
VLC/MPC Video Output Problems Suddenly
By usarin in forum Software PlayingReplies: 4Last Post: 24th Jun 2008, 12:29 -
AC3 audio is output as PCM to my receiver using SPDIF connection
By Daft in forum AudioReplies: 8Last Post: 7th Mar 2008, 14:45
