    Nov 2004
    australia
    I have VLC 0.8.6 installed.
    I have tried to play Divx's with 5.1 ac3 ....and
    DVDs with 5.1 Ac3 soundtracks.
    But it doesnt work!!
    I just get a kind of pulsing sound when I select the
    A/52 over SPDIF!!
    I can play stereo option.
    I have my motherboard/onboard sound connected via optical link
    to my 5.1 surround sound amp.
    I can get 5.1 Ac3 sound output via this link
    when using media player classic 6.4.9
    and zoom player 5!!
    But for some reason all I get when I try and select
    A/52 over SPDIF...as I said ...is a kind of pulsing noise.
    its almost like the soundtrack is out of phase/sync...
    Its so annoying ...anyone have suggestions or tips to fix this?????
    TIA Aussiemac
  2. Less than meets the eye. Phlexor's Avatar
    Jun 2001
    Victoria, Australia
    Have you tried this?
    Go to [Preferences] and check [Advanced Options]
    Then Expand [Audio] and select [Output modules]
    Change [Audio output module] to [Win32 waveOut extension output]
    Then click on [Save] and quit and re-start VLC
    Try SPDIF output after all that and hopefully it should work.
    Nov 2004
    australia
    The Easter bunny has delivered early!!!....Thank you!!!
    This little problem has been round for awhile ...
    and never... could I change a
    setting to beat it....then low and behold!! ....in a religious spirit ...hehe!!
    the solution is ...delivered!!...like a good batch of hot cross buns!!
    We have sound from all six speakers....and it aint no pulsing noise!!
    Thanks again...
    Aussiemac
