Yes, I'm embarassed to say this but I've never been able to use ImgBurn because I do not know how to use it.![]()
I'm confused by terms such as "Build." I know it is suppose to build something, but what exactly is it going to build? How is it going to go about building that something?
I've tried a few times but gave up getting confused and puzzled. Maybe I was lazy or the program is not built for simple Johns like me.
I'm used to Nero where i click once and a window comes up with VIDEO_TS and AUDIO_TS folders waiting for my VOB files to drop into them. Very simple!
I just can't figure out how to do it with ImgBurn. Is there a file preparation that is different from Nero that I have to do first before feeding them to ImgBurn? How can I burn with ImgBurn my reauthored VOB files from DVDShrink?
Can anyone point me to a step-by-step using regular dvd disc (single-layer) on how to use this program?
Please someone guide me on how to use this program from my VOB, BUP and IFO files from DVDShrink.
Thanks for reading this and your help.
Start ImgBurn
Hit ctrl+alt+B
Make sure your DVD writer is selected on the destination tab
Drag the VIDEO_TS folder that Shrink created into ImgBurn
Hit the device tab and select write speed
Hit the burn buttonHe's a liar and a murderer, and I say that with all due respect. -
Have you tried going to http://www.imgburn.com/ and reading?
Buy My Books -
Next time just have DVDShrink output as an .ISO Image instead of folders...that alone will make your life with ImgBurn a whole lot easier.Originally Posted by v-sharp
https://forum.videohelp.com/viewtopic.php?p=1681043
...or use DVDDecrypter to burn. -
I've barely tried to use it myself, due to similar confusion. However, there are what appear to be some pretty good (and brief) guides for the program linked here in the Tools section. I printed them out, and think they will do the trick, the next time I go to use it -- particularly for anything a bit more involved than what steveryan outlined for you, such as using it for dual layer media.Originally Posted by v-sharp
But do always check the Tools Section entry here for any guides. They will vary in quality and ease of following, but many of them are quite good. There are also guides to be found for many programs on sites like Afterdawn, Doom9, CDfreaks . . . . -
Thanks for the tips guys.
steveryan... I like the simpleness of your method (drag and drop the VIDEO_TS and AUDIO_TS folders). I tried it just now and it works for me. Thanks very much!!Start ImgBurn
Hit ctrl+alt+B
Hit the burn button
I just realized why I do not like iso output from dvdshrink and dvddecrypter because I like to run the movie files to check if theyre alright before burning to disc.
Thanks again to everyone and especially to steveryan!!
Nero vs ImgBurn: Why is ImgBurn preferred?
By usually_quiet in forum Authoring (DVD)Replies: 31Last Post: 28th Aug 2010, 17:47 -
Subs don't show properly I don't know what to do
By atai in forum SubtitleReplies: 1Last Post: 8th Oct 2009, 07:44 -
BD - RE to use with ImgBurn
By fjmr in forum Blu-ray RippingReplies: 7Last Post: 2nd Aug 2009, 21:08 -
Layer break problems. ImgBurn. Don't know what to do.
By tomcar in forum Newbie / General discussionsReplies: 5Last Post: 17th May 2009, 00:46 -
Upgraded to ImgBurn 2.2 - Now "ImgBurn Shell Ext" No Longer Works
By Cool Breeze in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 11th May 2007, 10:05
