I have a Drive LG GGW - H20L to record and copy BD.
I have already ripped with AnyDVD and backup with BD Rebuilder a BD Movie for burn in a BD-RE the output file of BD Rebuilder already in my HDD.
So I need now to buy a BD-RE but I have heard that there are some versions of BD-RE like 2.1, 3.0 and so on.
Is that right??
Wich one should I pick for burning my video output from BD Rebuilder.
Thanks.
Are you sure you want BD-RE's, not BD-R's?
BD-R's offer faster write times, cost less, and may offer higher compatibility
I buy Vinpower BD-R's to back up my fav BD movies (10 pack for $34.99USD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817607008
unless you want rewriteability
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html -
Thanks for your infos but here all them are very expensive so how I am in my first BD burning I would like first test to see if all is ok.
So I should buy a BD-RE to test before and if everything is ok then I will go for a BD-R.
So is there a specific version of BD-RE or can I use anyone??
Thanks again, remember I have Drive LG GGW H20L for burning BDs. -
from the little research I have done so far it seems that those lower spec discs were manufactured in 2007, and I doubt you will run into any todayOriginally Posted by fjmr
ocgw
Hi,
If it is 25 GB BD-RE you are looking for, I have tried Memorex BD-RE 25GB, Verbatim, Philips, and
one LG. LG started to go bad after 8-10 use. Whereas the others seem to be good.
I have same burner as you have. I got BD-RE 3 pack from frys.com for 19.99 + shipping a while ago.
I have been using Memorex BD-R 25 GB. They work very well -
Yes it is BD-RE 25 GB.
I had one LG 25 GB BD-RE also that came with the LG Drive but it was quite bad.
It died after tree burnings and is impossible to erase it.
I load it and it stay there forever.
But finally I think that nowadays BD-RE has a standard version so I can buy one without worry about versions.
Is it that??? -
Stay away from the LG.Originally Posted by fjmr
The one (BD-RE) that came with the Drive was bad. After bugging the LG for 6 weeks they sent a replacemnt.
That was not good. After 6 or so rewrites, it died. pick memorex or verbatim.
ImgBurn
By didikai in forum Newbie / General discussionsReplies: 10Last Post: 17th Apr 2012, 23:18 -
Nero vs ImgBurn: Why is ImgBurn preferred?
By usually_quiet in forum Authoring (DVD)Replies: 31Last Post: 28th Aug 2010, 18:47 -
How do i use IMGBURN?
By mrjust in forum Newbie / General discussionsReplies: 6Last Post: 10th Apr 2009, 14:35 -
ImgBurn
By gomer in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2009, 00:35 -
Upgraded to ImgBurn 2.2 - Now "ImgBurn Shell Ext" No Longer Works
By Cool Breeze in forum SVCD2DVD & VOB2MPGReplies: 8Last Post: 11th May 2007, 11:05
