  1. Yes, I'm embarassed to say this but I've never been able to use ImgBurn because I do not know how to use it.
    I'm confused by terms such as "Build." I know it is suppose to build something, but what exactly is it going to build? How is it going to go about building that something?
    I've tried a few times but gave up getting confused and puzzled. Maybe I was lazy or the program is not built for simple Johns like me.
    I'm used to Nero where i click once and a window comes up with VIDEO_TS and AUDIO_TS folders waiting for my VOB files to drop into them. Very simple!
    I just can't figure out how to do it with ImgBurn. Is there a file preparation that is different from Nero that I have to do first before feeding them to ImgBurn? How can I burn with ImgBurn my reauthored VOB files from DVDShrink?
    Can anyone point me to a step-by-step using regular dvd disc (single-layer) on how to use this program?
    Please someone guide me on how to use this program from my VOB, BUP and IFO files from DVDShrink.
    Thanks for reading this and your help.
  2. Member steveryan's Avatar
    Jan 2003
    Manchester
    Start ImgBurn
    Hit ctrl+alt+B
    Make sure your DVD writer is selected on the destination tab
    Drag the VIDEO_TS folder that Shrink created into ImgBurn
    Hit the device tab and select write speed
    Hit the burn button
    He's a liar and a murderer, and I say that with all due respect.
  3. Member gadgetguy's Avatar
    Feb 2002
    West Mitten, USA
    Have you tried going to http://www.imgburn.com/ and reading?
    Buy My Books
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Originally Posted by v-sharp
    Ye How can I burn with ImgBurn my reauthored VOB files from DVDShrink?
    Next time just have DVDShrink output as an .ISO Image instead of folders...that alone will make your life with ImgBurn a whole lot easier.
  5. Member Seeker47's Avatar
    Jul 2005
    I've barely tried to use it myself, due to similar confusion. However, there are what appear to be some pretty good (and brief) guides for the program linked here in the Tools section. I printed them out, and think they will do the trick, the next time I go to use it -- particularly for anything a bit more involved than what steveryan outlined for you, such as using it for dual layer media.
    But do always check the Tools Section entry here for any guides. They will vary in quality and ease of following, but many of them are quite good. There are also guides to be found for many programs on sites like Afterdawn, Doom9, CDfreaks . . . .
  6. Thanks for the tips guys.
    Start ImgBurn
    Hit ctrl+alt+B
    Hit the burn button
    steveryan... I like the simpleness of your method (drag and drop the VIDEO_TS and AUDIO_TS folders). I tried it just now and it works for me. Thanks very much!!
    I just realized why I do not like iso output from dvdshrink and dvddecrypter because I like to run the movie files to check if theyre alright before burning to disc.
    Thanks again to everyone and especially to steveryan!!
  7. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    Here is a tip. VLC can play the ISO file as if its an actual DVD already.
