How do I resize avi/mpeg files to make them smaller
Ex. For use as avatars & sigs (which ill be converted to gif of course)
And I want to remove the black lines on some of the avis I want to resize too.
Coz They were ripped from dvds
Free software is better of course
If you know a software taht you use and is easy
Pls point me the right place and aguide too if possible
Virtualdubmod or virtualdubmpeg2, select video->filter and add the resize filter and then video->filters and click on cropping and last file->save avi. Use super and convert to a gif animated video.
Anyway,
Its good but is there any software to do manual croping?
Insteadof using variables as offsets?
I meanusing your mouse to crop?
I find that easier. Thanks -
Question
I tried resizing to 90 x 90 pixels to use the vid as my avatar
But what happens is when I use that width and height the video is duplicated or what you would call somewhat cropped
When I use 150 pixels and above its fine
Resize & Crop MKV
By Kand in forum Video ConversionReplies: 2Last Post: 22nd Apr 2012, 14:50 -
Can I crop and resize video?
By maldb in forum EditingReplies: 6Last Post: 13th Jun 2009, 20:06 -
Video Crop and resize
By quxote in forum EditingReplies: 4Last Post: 27th Feb 2009, 12:48 -
Crop/resize mpeg-2 to remove pop-up ad
By CaZeek in forum EditingReplies: 9Last Post: 8th Sep 2008, 23:43 -
Software To Crop A Video & Encode It In .avi Format
By rahul.never2far in forum Video ConversionReplies: 2Last Post: 25th Sep 2007, 03:50
