    Mar 2007
    Philippines
    How do I resize avi/mpeg files to make them smaller
    Ex. For use as avatars & sigs (which ill be converted to gif of course)
    And I want to remove the black lines on some of the avis I want to resize too.
    Coz They were ripped from dvds
    Free software is better of course
    If you know a software taht you use and is easy
    Pls point me the right place and aguide too if possible
    Virtualdubmod or virtualdubmpeg2, select video->filter and add the resize filter and then video->filters and click on cropping and last file->save avi. Use super and convert to a gif animated video.
    Mar 2007
    Philippines
    thanks
    Mar 2007
    Philippines
    Anyway,
    Its good but is there any software to do manual croping?
    Insteadof using variables as offsets?
    I meanusing your mouse to crop?
    I find that easier. Thanks
    Mar 2007
    Philippines
    Question
    I tried resizing to 90 x 90 pixels to use the vid as my avatar
    But what happens is when I use that width and height the video is duplicated or what you would call somewhat cropped
    When I use 150 pixels and above its fine
