Hi,
I have several .rm (real media) files which are pretty big in size (~400 MBs). This is because the files contain 6 different kind of audio and video streams for 6 different audience types (corresponding to different bitrates). What I want is to keep the only 1 audio and 1 video stream having the maximum bitrates and strip off the remaining streams. I don't want any sort of re-encoding of the data as the quality would degrade. Is there any tool which can help me do this?
I have tried using Real Media Editor from real networks but it does not have any such option.
Thanks in advance
Results 1 to 9 of 9
I tried using the program SureStream but when I click Add button and select the file, the program quits without giving any errors. Whats the problem?
the file you need to use is GUIMergeSS.exe which is inside the surestream.zip file . GUImux.exe will not work with file containing multiple audio/video streams.
Yeah, I used the same file. But as soon as I selected the .rm file, the program quits without giving any warning or error.
try downloading file from doom9 link i gave. your file may be corrupted.
also check with other rm files-specific file you are trying maybe corrupted
i checked again with my copy-no problems -
mgh
Its the same program which I downloaded from the link that u have given... but the program is quitting without giving any errors or warnings -
try the file i have-if it also does not work, try capturing through a streaming download utility
guimergess.rar -
I tried merging but an error occurs, and shut down the entire programe.
Can Real Media files (.rm, .rmvb) be demuxed?
By Huh...What? in forum Video ConversionReplies: 5Last Post: 4th Mar 2010, 10:06 -
A simple trimmer for real media files
By kutchbhi in forum Newbie / General discussionsReplies: 7Last Post: 22nd Sep 2009, 07:29 -
converting .rm real media files to .avi or .mpeg
By tilopa88 in forum Video ConversionReplies: 5Last Post: 25th Jul 2009, 09:45 -
Problem editing dvr-ms files from windows media center
By justinstrack in forum EditingReplies: 4Last Post: 2nd Jun 2009, 08:29 -
Conversion tool for Real Media files to avi to burn to dvd
By loninappleton in forum Video ConversionReplies: 17Last Post: 29th May 2007, 13:30
