Hi.
Forgive me if this has been asked a hundred times, but I didn't find anything in a forum search.
Can Real Media Player files like .rm/.rmvb be demuxed, and what would be the best option to do it?
It doesn't seem to support demuxing.
Frameserving isn't viable as that requires installing some type of shell, and I need a portable option. -
There isn't an extract option in RMMuxer, unless after opening the video, I just save it again without the audio, or video, stream checked.
DTDrive only saves the the audio as a ".rm", and video as a ".rmvb". That kind of defeats the purpose of demuxing if it only seperates the streams into 'two' Real Player format files.
I need the actual RV40 'H.264' video, and the 'Cook' audio for repacking/converting into mkv/mp4 format.
-edit-
Nevermind. I've realized there is now way to just remux the files into another format. They'll have to be recompressed, with quality loss.
Thanks for the help.
Unfortunately, yes.
But not quite... it is possible to put RealMedia A/V in MKV container (used MKVtoolnix) - however, it is awkward to play later.
RV40 is only suspected to be based on H.264 - simplify, is not consistent with MPEG-4 AVC specification.VideoAudio.pl - Serwis o technologii wideo & audio
How to Convert RMVB(Real Media Variable Bitrate) to AVI
By deletrius in forum User guidesReplies: 62Last Post: 5th Apr 2011, 08:36 -
A simple trimmer for real media files
By kutchbhi in forum Newbie / General discussionsReplies: 7Last Post: 22nd Sep 2009, 07:29 -
converting .rm real media files to .avi or .mpeg
By tilopa88 in forum Video ConversionReplies: 5Last Post: 25th Jul 2009, 09:45 -
Converted rmvb Real Media to avi - no sound
By mano1438 in forum Video ConversionReplies: 2Last Post: 25th Aug 2007, 13:28 -
Conversion tool for Real Media files to avi to burn to dvd
By loninappleton in forum Video ConversionReplies: 17Last Post: 29th May 2007, 13:30
