I have a bunch of real media files , from which I need to extract scenes from. So I need a simple trimmer that could just yank off a couple a minutes of video.
I tried avs4you - it can trim the video , but when it comes to the saving part it re-encodes the video into something very fat (i terms of MB's).
I am hoping here something that can just instantly extract video from a clip based on time. It doesn't even have to have a preview feature. Just copy 1 minute of video from this video into another file, with same quality/size .
Anything like this ?
use real producer basic (free)
Under File menu-click Edit real media
you will get a nice gui with preview
use double arrow buttons to cut at key frames and save -
I tried real producer. But it seems it doesn't take .rm files in input.
REVE didn't work either.
My files have the .rm extension and are probably encoded in xvid.. -
That's two entirely different formats/codecs.Originally Posted by kutchbhi
I would drop one into MediaInfo and see what format it is.
If you just want to edit in RM format, Real is a very proprietary format and there aren't many editors out there for it. And RMVB is usually variable bitrate video and audio, which makes it even harder to accurately edit. It was designed as an end format, not something to be edited.
You may also have difficulty joining the cut part with another RM file.
Just my method, but what I do with RM(VB) files is drop them into Any Video Converter Free Version and convert them to some format simpler to work with than RM.
Or you can use HuffyUV for an intermediate format with the program and there should be no quality loss. Edit in HuffyUV with VD or AVIDemux, then re-encode to the final format you want. HuffyUV will give you a very large file size, but just delete the file after you have edited and converted it. That method will preserve most of the quality if they have to be re-encoded.
And welcome to our forums.
I don't use avs4you, but if it does give you an AVS file that renders the RMV, you can open that AVS file in Virtualdub and save it as AVI, choosing whatever video and audio compression you like (the default is no compression, which is very large, which may be what you are getting now).Originally Posted by kutchbhi
If it helps, I used this AVS script to process an RMVB video:
Code:DirectShowSource("A_3.rmvb", fps=25, convertfps=true) EnsureVBRMP3sync() SSRC(48000,false) LanczosResize(720,576)
Can Real Media files (.rm, .rmvb) be demuxed?
By Huh...What? in forum Video ConversionReplies: 5Last Post: 4th Mar 2010, 10:06 -
converting .rm real media files to .avi or .mpeg
By tilopa88 in forum Video ConversionReplies: 5Last Post: 25th Jul 2009, 09:45 -
real media to avi help
By odiedog in forum Video ConversionReplies: 5Last Post: 18th Jan 2009, 05:10 -
HD DVD .EVO to .MKV (I need a real simple method)
By craig198 in forum Blu-ray RippingReplies: 0Last Post: 26th Aug 2008, 13:24 -
Conversion tool for Real Media files to avi to burn to dvd
By loninappleton in forum Video ConversionReplies: 17Last Post: 29th May 2007, 13:30
