Hi, I am trying to convert my CDs to ISO format. I have Nero 6 but it can only allow me to convert to nrg format, but not to iso format. I have also installed DVD Decryptor but it can only convert DVDs to ISO, it can't convert CDs to ISO.
Can anyone suggest a free software which I can use to convert my CDs to ISO format?
Thanks!
Closed Thread
Results 1 to 21 of 21
daemon tools? Check the tools section on the left of the screen for more options.
I have installed daemon tools but it can only mount images, it can't convert my CDs to iso format.
Thanks!
I have installed Imgburn, but it can only burn image into CDs, it can't convert CDs to iso image.
Thanks!
You missed the suggestion for isobuster - I think that was epicurius. Try it out.
my way to do it is to rip disk into an .nrg image using Nero and then convert the .nrg into .iso with CDBurnerXP. hope it helps.
http://www.cdburnerxp.se/features.php
And from memory there was a freeware utility that converted from most formats to iso ... just dont recall the name of it right now .
Here's a couple :
http://www.dubaron.com/cd2iso/
http://www.softplatz.com/Soft/Audio-Multimedia/Video-Tools/29027.exe
http://isorecorder.alexfeinman.com/isorecorder.htm
http://www.paehl-info.de/cdr/convertIso.php
Found the stupid thing ... http://cdmage.orcon.net.nz/frames.html
Do I know some ... more to poke that stick at ...
Or http://www.kvipu.com/CDCheck/ to rip them all to hd folder , and imgburn to iso ... bit more technical ...
Look again in Nero Burning Rom. When using Image Recorder when you go to burn/save from the drop down choose 'ISO'.Originally Posted by lockherin
Using version 6.
Hi all,
I have been trying out all kinds of conversion tools like isobuster, ultraiso, and magiciso. I noticed that all of these tools are able to easily convert an audio CD into bin/cue format, but are unable to convert it to iso format.
The reason given by the error pop-up is that the cd is an audio cd or the cd is multi-session. I guess the only way is to first convert the audio cd to bin/cue format and then convert from bin/cue format to iso format.
I am not sure why is it this way but I am interested to know why it happen this way. Can anybody kindly explain this technical phenomenon to me? Thanks in advance!
the easy answer is that iso is for data, and not audio. the cue file is required to tell the burner what mode to burn the files in. for more info search for the "red book" of cd standards. there are many modes of burning cds.
There are a bunch of "formats" for disc images. Some work better than others, depending upon what kind of data it is and how you're going to use it.
The 2 different kinds of disc images are "RAW" and "COOKED"
RAW contains 1. User data, 2. Error detection/correction codes, 3. Track and/or Session marking info (Lead in and program PQ data), and sometimes 4. Full R-W subcode data.
COOKED contains only 1. User data.
By nature, if you have a cooked image, you can't tell if it's multi-session or not, or which mode it's supposed to be burned in. There are of course some image formats that are hybrids, using cooked files and a meta-file to tell how to burn, as well as some variations of cooked files where the additional info has been appended.
CUE/BIN is a type of RAW format (the BIN is the image, the CUE is the meta-file)
ISO is usually a COOKED format, containing only the 2048 byte data found in Mode1 or Mode2Form1 discs. They are almost always single track/single session. ISOBuster and a few others do support multi-track/multi-session versions (exceptions).
***If you've got a multi-session audio disc, a CUE/BIN is the natural way to go. Converting again to ISO (or any variation) might lose the additional info needed to correctly interpret the image. Keep it as CUE/BIN. It can be viewed (unmounted) with ISOBuster, it can be mounted with DaemonTools, it can be burned with CDRWin/Fireburner. Why change it?
HiOriginally Posted by Cornucopia
here is my problem a just downloaded a rock band concert and of course it has sound and video. i downloaded a two file folder a bin file and a cue file the bin file is 4.35 Gb and the cue file is 1 Kb. id like to burn it to a dvd so ive trying to convert the file to an iso image by means of bin2iso.exe i also used isobuster to extract the files and create a dvd disk with those files but nothing seems to work
plz hlp
regards
Open the CUE file with a text editor (notepad, etc). That's all it is anyway--text.
Copy/Paste what you've got (obfuscating any personal/intimate/incriminating data!)
It might have track types of "Audio" "WAVE" "BIN" "Mode1" Mode2Form1" etc. This will help you (or us) figure out what you can do with it.
Note: it sounds like you've got a DVD image (by the size of it). But that's strange, because they don't usually come as CUE/BINs.
Might be easiest to just try a test burn with Decrypter or ImgBurn, just choose the BIN and see what happens.
Cornucopia:
Thanks for your concern to my problem
i opened the cue file and i got this:
FILE "rammsstein_volkerball _ full dvd_ iso_ psychobob rocks !!!.bin" BINARY
TRACK 01 MODE1/2048
INDEX 01 00:00:00
And as u said before it is strange cuz due to all the searched ive done in the Internet about this thing i agree that cue/bin files are cd disk file type.
I try to change the extension from bin to iso but it didnt work
Plz hlp
Regards
You are in breach of the forum rules and are being issued with a formal warning. Buy it on DVD http://www.rammstein.de/_SimpleBall/Voelkerball/
/ Moderator Baldrick
compare iso image with DVD/CD
By perfection in forum Newbie / General discussionsReplies: 14Last Post: 26th Jun 2011, 13:38 -
Help Converting an ISO Image File into a DVD Format playable on DVD players
By Gradyj in forum Newbie / General discussionsReplies: 5Last Post: 19th May 2010, 21:13 -
Subs getting altered when converting DVD image (iso) to mkv in HandBreak
By Ronin Silfar in forum SubtitleReplies: 5Last Post: 5th Feb 2010, 03:26 -
Saving ISO image file?
By Mort439 in forum Authoring (DVD)Replies: 12Last Post: 28th Mar 2009, 12:17 -
create a dvd menu from iso image
By DSLGuy in forum Authoring (DVD)Replies: 3Last Post: 19th May 2008, 10:30
