Is there any software (apart from Imgburn) that can compare the data on a (burned) DVD/CD with its iso image file AFTER BURNING?
				Results 1 to 15 of 15
	No it can't
 (That's assuming the OP means as a standalone operation - it's not exacly clear what 'after burning' means - straight after burning or 1 week later?!)
 You could Read the disc to another image file and MD5 the two image files though.
	Mount the ISO using eg Daemon Tools, then you can compare the files in the ISO with those on the disc, using standard tools (eg, MD5 them).
	ImgBurn (freeware) can do that even one week after burning
 The ImgBurn ‘Verify disc’ function will check if the data written to the disk is readable.
 2. To verify a disk against ISO file with ImgBurn, choose ‘Verify disc’ (9).
 3. Click the browse icon (10) and select the ISO file that you use to burn the disk. Make sure you inserted the disk that you want to verify to your CD/DVD drive. Select the CD/DVD drive (11) that contains the disk that you’ve burn before. Press the start icon (12) to start the disk verification process.
 Disk verification process in progress
	I thought it did a byte by byte comparison as the verify was being done.
 How can it compare hash values while it's still running? Hash values for each sector?
  How to Extract an ISO Image without burning to dvd?By skorpinok in forum ComputerReplies: 8Last Post: 26th Sep 2018, 03:07
  Subs getting altered when converting DVD image (iso) to mkv in HandBreakBy Ronin Silfar in forum SubtitleReplies: 5Last Post: 5th Feb 2010, 03:26
  create a dvd menu from iso imageBy DSLGuy in forum Authoring (DVD)Replies: 3Last Post: 19th May 2008, 10:30
  Standalone DVD Player to read iso image and VTS filesBy bluemoss in forum DVD & Blu-ray PlayersReplies: 6Last Post: 19th Nov 2007, 15:45
  Can't burn .iso image file onto the DVD+RBy BabaKali in forum Newbie / General discussionsReplies: 12Last Post: 26th Sep 2007, 06:44
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
