When converting an iso file into mkv using HandBreak I get the result shown in my image uploads. SubExmpale1.png is the source, and the second is from the resulting mkv. Notice particularly the green glow surrounding the text. The fact that it lost it's color isn't a big deal to me, but the green glow is distracting. What is causing this, and is there a easy fix or do I have to export the subs manually then mux them in later?
Thanks in advance for your help! ^_^
edit: Zoom in with ur browser if you have a hard time seeing it. It's quite obvious when watching the vid, but no so much on the picture.
You can try strip the subs from the DVD using vsrip and then add it to the mkv using mkvmergegui. And see if it looks better.
I ripped the subs and they still have that green glow when muxed back in. I haven't tried coloring them though, I just left them white. Should I try to match their original color?
This happens on more than just this particular file. Every job I've done so far comes up w/ color-stripped glowy subs.
How to keep the subs of an mkv when converting to dvd?
By Akhet in forum Newbie / General discussionsReplies: 3Last Post: 26th Sep 2011, 12:08 -
Converting mkv to dvd always results in an oversize iso
By Akhet in forum Newbie / General discussionsReplies: 3Last Post: 25th Sep 2011, 00:16 -
AVCHD (DVD) .ISO file, trying to extract original MKV from DVD image
By SkEvolver in forum Blu-ray RippingReplies: 12Last Post: 11th Aug 2011, 06:55 -
By SkEvolver in forum Authoring (DVD)Replies: 1Last Post: 3rd Jul 2008, 21:34 -
Help converting MKV to DVD with unusual subs.
By Kyo in forum Video ConversionReplies: 3Last Post: 1st Jun 2007, 14:31
