hi
i have started using dvd-lab pro 2 which is a great tool but i have one problem, when i import the subtitles, the times are different to the actual srt or sub file. Does anyone know why and how to fix this???
i've posted a pic so you can see what i mean.
thanks
roy
Maybe,
or search and post in http://www.mmbforums.com/phpbb/viewtopic.php?t=6206&highlight=srt+syncIn the subtitle window is an option called ‘time code is written in’. At first I selected the ‘real time (25&29.97 fps)’ with the result that the generated subs are out of sync. When I select the ‘Non drop frame (30 fps)’ and generate the subtitle stream, they are perfectly sync. -
There's nothing wrong with the times - read my answer on this thread:
https://forum.videohelp.com/viewtopic.php?p=1613812#1613812
And as Baldrick just quoted, use NDF for the DVD subs.
Though it looks like in version 2.21 they changed things:
-Changed, Fixed and Cleaned - Subtitle Timecode, now you should always use the Real Time 25fps & 29.97 fps settings for your subtitles. But there are two other options Correct if subs show early and Correct if subs show late, use these if at some point the DF/NDF is incorrect in your subtitles, this will correct it in the right dirrection and hopefully end the confussion about NDF and DF subtitles. -
hi,
i tried the NDF option and it looks like it has worked.
thanks for the replies!
[DVD Lab Pro] subtitles wrong time
By dom61 in forum Authoring (DVD)Replies: 2Last Post: 4th Sep 2011, 08:42 -
Off-sync subs in DVD Lab Pro
By carlmart in forum Authoring (DVD)Replies: 4Last Post: 17th May 2011, 23:22 -
DVD-Lab Pro: Subtitles change text
By TheLaserdisc in forum Authoring (DVD)Replies: 8Last Post: 18th Aug 2010, 13:23 -
Subtitles problem in DVD-lab pro
By spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 16:14 -
out of sync subtitles - DVD Lab Pro
By GangstaRap in forum Authoring (DVD)Replies: 2Last Post: 12th May 2007, 16:57
