Hallo to everyone!
I’m using DVD-lab pro 2 for dvd authoring
And the problem is that: Some subtitles
use italic characters in some lines, for example:
00:01:04,274 --> 00:01:06,390
Thebes: City of the Living.
But in DVD-lab pro those lines appears as normal text
Any ideas
	It doesn't support it. See http://www.mmbforums.com/ipb/index.php?showtopic=20537
 You can either use something else to make subtitle or remove the [i] with a text editor(use replace-function).
  [DVD Lab Pro] subtitles wrong timeBy dom61 in forum Authoring (DVD)Replies: 2Last Post: 4th Sep 2011, 08:42
  DVD-Lab Pro Subtitles Encoding troublesBy laste in forum Authoring (DVD)Replies: 1Last Post: 16th Jan 2011, 15:12
  DVD-Lab Pro: Subtitles change textBy TheLaserdisc in forum Authoring (DVD)Replies: 8Last Post: 18th Aug 2010, 13:23
  Help with audio problems on dvd-lab pro and / or subtitles on a dvdBy Jack the Ripper in forum Newbie / General discussionsReplies: 12Last Post: 7th Dec 2007, 19:00
  out of sync subtitles - DVD Lab ProBy GangstaRap in forum Authoring (DVD)Replies: 2Last Post: 12th May 2007, 16:57
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
