I dont understand why, but DVD-lab pro is changing my subtitles, here is the example
Original Source
DVD-Lab Pro DVD
It looks fine when I put it into the program, so I don't know what is wrong. Can I get some help?
Results 1 to 9 of 9
Anime on Laserdisc is teh awesome
Does anyone know whats causing this?
Anime on Laserdisc is teh awesome -
Ok, I looked it up, the subtitle that keeps on replacing the other subtitles is from an older project, is there a way to clear my history to prevent this from happening?
unless you added the wrong subs they wouldn't be in a new project.
Well they keep on popping up, I know the srt files are right, I checked them all myself.
I checked them manualy, in VobsubResync, and in DVD-Lab pro, the screen where you import the subtitles, its all ok there. Just after compiling it changes.
I'll attach the subtitles to this postAnime on Laserdisc is teh awesome -
So, would uninstalling and deleting DVD-lab pro in my registry clean this up?
dvd lab pro - text labels as buttons - problem
By pike8 in forum Authoring (DVD)Replies: 2Last Post: 21st Apr 2012, 06:03 -
How to change menu aspect ratio in DVD-Lab Pro ?
By V879 in forum Authoring (DVD)Replies: 2Last Post: 1st May 2011, 16:11 -
Jumping Text on Motion Menu in DVD Lab Pro 2
By christopheramos in forum Authoring (DVD)Replies: 0Last Post: 21st May 2008, 07:32 -
Can you change bmp subtitles size without converting them first to text?
By Talayero in forum SubtitleReplies: 3Last Post: 9th Feb 2008, 11:43 -
out of sync subtitles - DVD Lab Pro
By GangstaRap in forum Authoring (DVD)Replies: 2Last Post: 12th May 2007, 15:57
