hi
i have started using dvd-lab pro 2 which is a great tool but i have one problem, when i import the subtitles, the times are different to the actual srt or sub file. Does anyone know why and how to fix this???
i've posted a pic so you can see what i mean.
thanks
roy
	Maybe,
 or search and post in http://www.mmbforums.com/phpbb/viewtopic.php?t=6206&highlight=srt+syncIn the subtitle window is an option called ‘time code is written in’. At first I selected the ‘real time (25&29.97 fps)’ with the result that the generated subs are out of sync. When I select the ‘Non drop frame (30 fps)’ and generate the subtitle stream, they are perfectly sync.
	There's nothing wrong with the times - read my answer on this thread:
 https://forum.videohelp.com/viewtopic.php?p=1613812#1613812
 And as Baldrick just quoted, use NDF for the DVD subs.
 Though it looks like in version 2.21 they changed things:
 -Changed, Fixed and Cleaned - Subtitle Timecode, now you should always use the Real Time 25fps & 29.97 fps settings for your subtitles. But there are two other options Correct if subs show early and Correct if subs show late, use these if at some point the DF/NDF is incorrect in your subtitles, this will correct it in the right dirrection and hopefully end the confussion about NDF and DF subtitles.
	hi,
 i tried the NDF option and it looks like it has worked.
 thanks for the replies!
  [DVD Lab Pro] subtitles wrong timeBy dom61 in forum Authoring (DVD)Replies: 2Last Post: 4th Sep 2011, 08:42
  Off-sync subs in DVD Lab ProBy carlmart in forum Authoring (DVD)Replies: 4Last Post: 17th May 2011, 23:22
  DVD-Lab Pro: Subtitles change textBy TheLaserdisc in forum Authoring (DVD)Replies: 8Last Post: 18th Aug 2010, 13:23
  Subtitles problem in DVD-lab proBy spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 16:14
  out of sync subtitles - DVD Lab ProBy GangstaRap in forum Authoring (DVD)Replies: 2Last Post: 12th May 2007, 16:57
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
