Hi,
A buddy recorded something for me on his camcorder. It's one of those that burn the video directly to a small DVD (the type that fit in the center of your CD/DVD drive).
He swears he recorded it correctly. The disc is a Maxell 1.4 GB DVD-R disc. But I cannot read it at all. But my DVD player and the DVD burner on my PC can all types of DVD (+/-, R, RW, etc.)
It's almost as if the disc is blank. I can see the drive in My Computer, but it tells me there's no disc in the drive.
Is there something funky you have to do to access/view one of these small camcorder discs?
Thanks.
That's what I'm worried about. If he failed to do so, and I have the disc in my possession, is there anything I can do? If I get his camcorder (or a similar one), can I finalize it myself? Or am I SOL since he's ejected it?
I don't know if you need the original Camcorder to finalize the disc or not. Check out this other post. It sounds pretty similar.
https://forum.videohelp.com/viewtopic.php?t=312042 -
I hope it works for you. Let us know.
If it doesn't work, then I'm sure others that have more personal experience with these disks will chime in. -
I suspect it could be finalized if you put it back in the camcorder.Originally Posted by imrealdumb
what do i do to make a dvd movie small enough to fit in one disc?
By polka in forum Authoring (DVD)Replies: 3Last Post: 24th Mar 2012, 02:53 -
reading a blu ray disc
By hardy in forum Newbie / General discussionsReplies: 2Last Post: 8th Dec 2010, 21:49 -
Damage Disc Reading Problem
By Teac23 in forum DVD RippingReplies: 18Last Post: 20th Mar 2010, 19:03 -
dvd reading lightscribe disc only
By jonij in forum Newbie / General discussionsReplies: 2Last Post: 14th Dec 2008, 16:12 -
Adobe Encore DVD disc reading issues in DVD Duplicator
By Mergebow in forum DVD & Blu-ray WritersReplies: 0Last Post: 2nd Jul 2007, 16:49
