Back a few years ago, I was in the market for a DVD recorder. I eventually got a Pioneer, which i'm very happy with. Unfortunately, while i was in the market for them, I did use a couple for a few days, to test out, before taking them back to the store. On one, a JVC dvd-recorder/vcr combo, i converted some very old tapes to DVD. The finished product was ok, but then i took the thing back to the store before finalizing the discs.
Is it possible at all to finalize the discs without using the original recorder? In this day and age, you would think there would be some software that would fix a disc, like if it needed finalized, it would use some sort of process to finalize the disc so it could be played on other equipment.
Any suggestions?
You'd have to find a JVC or newer ES-series Panasonic recorder to finalize those JVC-made discs.
If you can't find a way to finalize it, you might be able to recover the data with isobuster.
Buy My Books -
Just a thought but if it is only a few DVD discs then you might be able to use a retail store display model if you can find one and if you do it very quickly before the store employees catch on LOL
Samsung R155 DVD Recorder - "Recorded" or "Blank"?
By mhamini in forum DVD & Blu-ray RecordersReplies: 3Last Post: 6th Feb 2010, 19:01 -
Aldi/Tevion DVD recorder "HDD DVD 160 MkII" - tech info, region f
By fzabkar in forum DVD & Blu-ray RecordersReplies: 0Last Post: 11th Jun 2008, 21:04 -
JVC SR-MV40US "Disc Error" on ANY dvd/cd ... a known COMMON flaw?
By ggoat!!! in forum DVD & Blu-ray RecordersReplies: 7Last Post: 10th Nov 2007, 02:58 -
JVC DR-MH30S DVD-RW "No Disc" error
By snook001 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Sep 2007, 13:50 -
Did "Good" media go bad -OR- DVD Recorder conundrum? Help!
By MrCreosote in forum MediaReplies: 9Last Post: 11th Sep 2007, 19:33
